Home > Faults & Fixes > Steering wheel shake HELP
ifelton76
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Sumatra Black
Hi All
I have a 2012 L320 Range Rover Sport 3.0 diesel autobiography with just over 71000 miles.
Since buying it 18 months ago I have been struggling with the steering wheel shaking when driving on the motorway (shake only seems to appear at 60 mph plus).
So far I have done the following
1 - New tyres
2 - New pads, disks and calipers
3 - New anti roll bar drop links
4 - New lower control arms
5 - Tried swapping front to back with the wheels
6 - Balancing and tracking
7 - Another new set of tyres
8 - Road force balanced all the wheels and had the tracking checked.
9 - Jacked the car up and checked for any play in the wheel bearings, steering and drive shafts
But still the steering wheel shakes, I'm running out of ideas can anyone help me at all.
Regards
Ian.
Post #624551 Mon May 30 2022 3:40pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
I've known this to happen when the wheels have been slightly out of shape. Also (and sorry if I missed it) have you had a Hunter Tracking Alignment done? Barrie.
2005 RRS 2.7TDV6 from 2017 -2024. Best car I ever had.
Current: 2018 Ford Ranger Wildtrak 3.2
Post #624552 Mon May 30 2022 3:48pm
ifelton76
Yes had the hunter tracking done this morning and tried swapping the wheels front to rear but still the problem persists, its starting to spoil my enjoyment of the car.
Post #624556 Mon May 30 2022 4:24pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
I suffered the same for a bit and my list was not as long as yours. It’s took 3 shops to balance the wheels and find a dodgy bush in the end. Since then and knock on wood all good. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #624557 Mon May 30 2022 4:43pm
BJH1959
Looking at what you've had checked, if the rims are all ok as in shape and weight and the bushes are all good then maybe loose motor mounts. That's all I can think of. Barrie.
Post #624559 Mon May 30 2022 4:49pm
ifelton76
Hi Puslinch which bush did you find was bad?
Post #624561 Mon May 30 2022 5:06pm
riverblanche
steering rack ends, steering rack itself, steering column UJ shaft Question
front lower arm rear bush can cause steering wheel wobble but you have done that already
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #624562 Mon May 30 2022 5:10pm
ifelton76
Thanks Riverblanche
Any idea how I go about checking these, Ive already tried jacking each wheel up and doing the usual play checks but couldnt see anything obvious
Post #624563 Mon May 30 2022 5:29pm
ifelton76
Hi just for info, been checking a few things on the sport this morning and I have checked all four wheels for left and right and up and down play with nothing obvious found. Also tried the steering for play and again nothing obvious. The only thing I found today was a very small amount of movement in the rear drive shaft center bearing.
The only question I have now is how much movement is acceptable?
Post #624583 Tue May 31 2022 3:19pm
Stevepd
Having recently had something similar, both my near side wheels were slightly buckled. Perhaps find a tyre place near you that can check. Cost £65 each but afterwards it’s smooth as a smooth thing. Surely it’s free to check?. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #624587 Tue May 31 2022 5:11pm
ifelton76
Update
I have the car booked in on Friday with K Motors in Leyland to see if they can diagnose the issue, so hopefully I will be able to update you all on Friday evening.
Also got told that another potential is the RHF drive shaft, as this is the longer of the two front drive shafts it has been known for them to bend slightly and cause the vibration.
Regards
Ian.
Post #624660 Mon Jun 06 2022 5:43pm
BJH1959
Hope you get it sorted and look forward to finding out what the. cause is / was! Barrie.
Post #624663 Mon Jun 06 2022 7:47pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
I have the exact same shaking at 60mph and i know 100% i need a new rear drive shaft which my indy is scheduled to do when i have time and the funds to get it in, So theres a good chance it is this part thats at fault with me having same issue on same vehicle.
Post #624673 Mon Jun 06 2022 10:44pm
ifelton76
Hi Jases4x4 do you get any vibration or shaking through the floor? I was out in mine yesterday and the only issue I get is the steering wheel shaking from left to right. Had a good feel around the floor and other areas and there was no other signs of vibration in the car.
Post #624674 Tue Jun 07 2022 10:23am
jases4x4
Non at all in the floor mate, Mines at exactly 60mph upto about 70mph and then goes abit, Rear Prop shaft was wearing last year and should hve had it done then but with other costs i have left until this service. Cost has doubled now aswell 🤦‍♀️
Post #624675 Tue Jun 07 2022 11:34am
