Home > Faults & Fixes > Steering wheel shake HELP |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 407 |
I've known this to happen when the wheels have been slightly out of shape. Also (and sorry if I missed it) have you had a Hunter Tracking Alignment done? Barrie.
Mon May 30 2022 3:48pm |
ifelton76 Member Since: 15 Dec 2020 Location: Merseyside Posts: 23 |
Yes had the hunter tracking done this morning and tried swapping the wheels front to rear but still the problem persists, its starting to spoil my enjoyment of the car. |
Mon May 30 2022 4:24pm |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 192 |
I suffered the same for a bit and my list was not as long as yours. It’s took 3 shops to balance the wheels and find a dodgy bush in the end. Since then and knock on wood all good. 2018 Telsa MS
Mon May 30 2022 4:43pm |
Looking at what you've had checked, if the rims are all ok as in shape and weight and the bushes are all good then maybe loose motor mounts. That's all I can think of. Barrie.
Mon May 30 2022 4:49pm |
Hi Puslinch which bush did you find was bad? |
Mon May 30 2022 5:06pm |
Mon May 30 2022 5:10pm |
Thanks Riverblanche
Mon May 30 2022 5:29pm |
Hi just for info, been checking a few things on the sport this morning and I have checked all four wheels for left and right and up and down play with nothing obvious found. Also tried the steering for play and again nothing obvious. The only thing I found today was a very small amount of movement in the rear drive shaft center bearing.
Tue May 31 2022 3:19pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Having recently had something similar, both my near side wheels were slightly buckled. Perhaps find a tyre place near you that can check. Cost £65 each but afterwards it’s smooth as a smooth thing. Surely it’s free to check?. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue May 31 2022 5:11pm |
Update
Mon Jun 06 2022 5:43pm |
Hope you get it sorted and look forward to finding out what the. cause is / was! Barrie.
Mon Jun 06 2022 7:47pm |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 225 |
I have the exact same shaking at 60mph and i know 100% i need a new rear drive shaft which my indy is scheduled to do when i have time and the funds to get it in, So theres a good chance it is this part thats at fault with me having same issue on same vehicle. |
Mon Jun 06 2022 10:44pm |
Hi Jases4x4 do you get any vibration or shaking through the floor? I was out in mine yesterday and the only issue I get is the steering wheel shaking from left to right. Had a good feel around the floor and other areas and there was no other signs of vibration in the car. |
Tue Jun 07 2022 10:23am |
Non at all in the floor mate, Mines at exactly 60mph upto about 70mph and then goes abit, Rear Prop shaft was wearing last year and should hve had it done then but with other costs i have left until this service. Cost has doubled now aswell 🤦♀️ |
Tue Jun 07 2022 11:34am |
