Home > Technical > Sport 5.0s/c
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Sport 5.0s/c
I have the engine management light on the fault code is
P0171-00 (AF) System too lean (bank 1)
When I drive the car it feels like no difference in power
Has anyone got info on the problem
Thanks
Cosmo
Post #624050 Thu May 05 2022 10:28pm
Cosmo15555
I’m still trying to find the problem
Post #624497 Wed May 25 2022 11:41pm
Could try swapping MAF sensors over bank 1 to bank 2 and visa-versa, if code changes to P0174-00 would indicate a faulty MAF sensor, as code refers to MAF and Cat sensors, also possible air leak on air intake system. The two sensors are identical and interchangeable just look different as they are mounted at different angles. Only a suggestion.
Post #624498 Thu May 26 2022 12:33am
Cosmo15555
I’ve not been in a hurry to remedy this as not caused any problem with performance
Sometimes I reset the engine light and no problem for a couple of weeks but then I’ll reset and comes straight back on
I’ve done a live data on both mass air flow sensors and getting different readings as shown in photo
Is this normal
Thanks
Cosmo
Post #625987 Sun Aug 07 2022 5:18pm
well -30 seams a silly value.
But worth someone else with the same engine checking, incase its a GAP problem.
next time check the long term fuel trims for bank 1 and bank 2
should be about 0-4
When it gets near 20, the light comes on
Post #625989 Sun Aug 07 2022 5:46pm
Cosmo15555
As I look at the car from the front which side is bank 1
Post #625992 Mon Aug 08 2022 12:02am
L/H side. R/H when sat in drivers seat.
Post #625993 Mon Aug 08 2022 12:21am
Cosmo15555
Thanks for the info
Post #625994 Mon Aug 08 2022 7:44am
Cosmo15555
I’ve cleaned the mass air flow sensors and still getting same reading so I swapped the sensors over and still the same reading as before
I checked the long term fuel and the readings are
Post #625996 Mon Aug 08 2022 6:22pm
Cosmo15555
Checking other different live values I’ve found this
Post #625997 Mon Aug 08 2022 6:58pm
Cosmo15555
After doing a lot of research on web some people saying pcv diaphragm can cause the same fault codes
I’m getting a noise I can only describe as when you blow through a fag paper getting a vibrating sound
I can also hear a hissing sound coming from around the area of the diaphragm’s
If this could be the cause has anyone changed them on the 5.0 supercharged engine
Post #625999 Mon Aug 08 2022 8:07pm
If you have a hisssing then fix it
Post #626000 Mon Aug 08 2022 8:17pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Post #626001 Mon Aug 08 2022 10:16pm
