Home > General (L494) > New RRS further info |
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1438 |
Mon Jan 31 2022 10:56am |
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 239 |
Fri Feb 11 2022 11:50am |
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 |
On the flip side I'd probably say it was a miss from me.
Sat Feb 12 2022 8:02pm |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 97 |
The back end of that looks tragic, much like the velar as mentioned. Is there any need for those twin shark fins - is one bigger one not big enough?
Sun Feb 13 2022 12:17am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
It's just an exercise in someone showing off their photoshop skills and their own personal design tastes. Perhaps wait until the real car arrives before deciding that the design is bad. 2012 SDV6 - it's missing a couple of cylinders
Sun Feb 13 2022 2:27pm |
I’d say the renderings are pretty close, they used the recent spy shots to compare
Sun Feb 13 2022 3:00pm |
Front, maybe so, although there's no guarantee that it's the end design. The rear is usually totally covered on prototypes with just enough holes for the lights to be visible. 2012 SDV6 - it's missing a couple of cylinders
Sun Feb 13 2022 6:22pm |
harisson Member Since: 28 Jun 2018 Location: CH Posts: 183 |
hello all
Mon Feb 14 2022 10:47am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1135 |
Can you imagine how good the driving will be in Dynamic mode with rear-wheel steering?
Mon Feb 14 2022 10:49am |
that rear end also agrees with this lastest spy shot (https://twitter.com/cars_pixels/status/1491020913202298882):
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Mon Feb 14 2022 10:53am |
Well, it is going to be dull then, isn't it.
Mon Feb 14 2022 11:18am |
Eagle77 Member Since: 21 Feb 2021 Location: Buckinghamshire Posts: 69 |
I am a bit meh about the renderings which I suspect are not too far off given the mule. To me at the front there is something a bit off around the area below the grille with the separate lower section accommodating the number plate (I think the current design makes the car look higher/more imposing since the number plate is quite high up).
Mon Feb 14 2022 2:45pm |
SDV6RRS Member Since: 08 May 2013 Location: Hampshire Posts: 52 |
The Autocar rear end (below) is much cooler. Agree that the render above is boring....
Wed Feb 16 2022 4:59pm |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 226 |
Given my age and when second-hand prices mean I am likely to be able to afford one, I could well be looking at my last car. RRS HSE Dynamic SDV6 2014
Thu Feb 17 2022 11:46am |
