Home > Technical > What is this wire? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4861 |
Have you had brake pads changed recently? being n/s/f wheel could be broken pad wear sensor wire, although thought that might throw a warning light up if it is.
Sat Jul 24 2021 3:33am |
ansariwn Member Since: 24 Jul 2021 Location: London Posts: 4 |
Hi, the break pad worn warning light has been ON for the last 3 weeks and the vehicle is booked for repairs on 11 August.
Sat Jul 24 2021 11:40am |
Yes I think it's the pad wear sensor wire, may have broken it when changing wheels, but if lights been on prior to changing wheels did you actualy check them when you changed the wheels?
Sat Jul 24 2021 11:50am |
No, I didn’t check the break pads when the wheels were being replaced. However, the dealership told me that the front pads have 5mm thickness and the back pads have 6mm thickness before they sold it to me in June.
Sat Jul 24 2021 12:46pm |
Your main problem is how worn the pads are, might need to drop wheel off to make it easier to see them, personally I would make sure the discs are o.k. if they are just stick a new set of pads in and renew the sensor, job done. Main Dealer will tell you, you need discs, pads and sensor at stupid money, as very unlikely they will do it under warranty as they will say it's a wear and tear item. Look for a good Indi rather than pay Main Dealer rip off prices.
Sun Jul 25 2021 2:45am |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 527 |
Totally agree as above….
Sun Jul 25 2021 8:46am |
Thank you for your replies. I am expecting the dealership will fix the issue (break pads) for me hopefully free of charge.
Sun Jul 25 2021 11:30am |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
They are consumables & chargeable, pads, discs & sensor Range Rover Sport: Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S |
Sun Jul 25 2021 1:11pm |
