Home > Technical > 2010 ace help please |
Darrenh Member Since: 05 Dec 2020 Location: Aberdeen Posts: 10 |
Anyone any ideas please |
Fri Jul 16 2021 5:45pm |
Are you saying the ARB actually pressurised and pulled one corner down?
Mon Jul 19 2021 8:26pm |
Rear pipes are connected correctly (they can only go one way when grouped together)
Mon Jul 19 2021 11:22pm |
Does the bottom pipe run from the pump? I think it does.
Tue Jul 20 2021 7:40am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4345 |
2 lower pipes go to the actuator
Tue Jul 20 2021 9:04am |
So at idle there should be no high pressure.
Tue Jul 20 2021 8:47pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 750 |
Britplumber (I think) did a post where he changed the front pipes with the body in site using high pressure fittings. Otherwise I think it has to be lifted. |
Tue Jul 20 2021 11:03pm |
At idle, there should be low pressure. High revs, high pressure The valve block is fairly simple. Opens one valve at each end to counteract the body roll one way, and moves it again to counteract the other way (essentially. Its more complex in operation) The valves are not serviceable. They are integral to the block The system is capable of producing 150bar of pressure Front end needs a body lift to replace the pipes in one piece |
Wed Jul 21 2021 6:54am |
Found this;
Wed Jul 21 2021 10:05am |
Bertbuckie Member Since: 04 May 2021 Location: Scotland Posts: 274 |
Sorry to jump on, but mine was idling the other day and I leant on the front passenger side of the bonnet, and mine dropped. Maybe they do move at idle? |
Wed Jul 21 2021 11:45am |
Valve blocks off and clear.
Wed Jul 21 2021 4:49pm |
Wed Jul 21 2021 4:50pm |
Mine actually pulled down about 3-4 inch |
Wed Jul 21 2021 6:10pm |
Same mate. I dont know why but it did. I was bumping it a bit, but still idle. Heard a creak so lent on and pushed.
Wed Jul 21 2021 7:27pm |
