Home > General (L494) > Knocking noise from rear wheels
kevin reevse Reeves
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
When pulling away on gravel or slippery surface there is a loud knocking from rear wheels, more noticeable when pulling out of left or right junctions from standstill. Problem was worse on gravel and uphill, when driving normally no noise. Car is a 2015 autobiography dynamic on 22" rims, as its not all the time it's not bushes, arms or CV joints I don't think. Dealers under warranty said it was tank slap🙄 I'm thinking more like dsc or traction control etc
but thought you experienced lot would maybe know what this may be......thank you.
Post #613967 Mon May 24 2021 8:29pm
ecs0set
I have a similar issue with my MY14.5 AB. When pulling away with the steering wheel turned, the rear diff seems to bind and cause a slight judder.
I have only just got the car and it has different make tyres front and back (all the same tread depth) so that could be a cause. Alternatively, I've seen the same issue reported on FFRR (google "Judder") and they reported that there is a known TSB and that a double-flush of the transfer box and reprogramming of the traction control resolves it.
My car is going into the dealer next Tuesday and so I am going to ask them if they know. If they want lots to investigate, I'll take it to the local LR specialist.
Post #614001 Tue May 25 2021 1:13pm
mees
Netherlands 2006 Range Rover Sport TDV6 HSE Java Black
Yes, i had the same. Double flush transferbox and new software and problem solved 😊
Post #614009 Tue May 25 2021 9:32pm
kevin reevse Reeves
Hi guys, so was your problem intermittent, how would I tell if that is the problem other than paying for it to be done and hope this is the issue?
Post #614010 Tue May 25 2021 10:49pm
Ash3
Hi Mees
Imy car has developed the same judder when turning from stationary.
How much did ot cost if you dont mind me asking please.
Post #614024 Wed May 26 2021 3:24pm
mees
Around 400 euro to solve this. Wasn’t cheap, but transformed the car
Post #614028 Wed May 26 2021 9:36pm
ecs0set
Main dealer confirmed, double flush transfer box and software update. They want £400+ for it, checky beggars, but then they also want £300 to replace a cracked rear fog light (they can FRO on that one)! Seems harsh when it's a problem LR made but then it could be a snapped crank so...
Will check if the local independant can do it cheaper.
Post #614203 Wed Jun 02 2021 8:26am
Ash3
I got a quote from Stratsone in Tottenham for £217 for double flush and renew.
Post #614213 Wed Jun 02 2021 10:55am
Ash3
Post #614215 Wed Jun 02 2021 11:56am
ecs0set
Sounds competitive! Although it's inside the North Circular so by the time I've paid Mr. Khan, it's probably about the same! Smile
Post #614216 Wed Jun 02 2021 12:29pm
kevin reevse Reeves
Hi guys, thanks for your valued comments, so I found the tech bulletin for this problem, does this mean the dealer should cover the work even if out of warranty?
Also found small oil residue around transfer case thus morning?
Post #614348 Sat Jun 05 2021 8:08am
ecs0set
I've had a quote from the local specialist for < £200 +VAT. No mention from the main dealer on LR contributing.
Do you have the details of the tech bulletin (so I can check the specialist is quoting for the right thing)?
Post #614503 Tue Jun 08 2021 1:13pm
kevin reevse Reeves
I can't upload the bulletin but the ref number is LTB00906NAS4, Google it.
Hope this helps
Post #614968 Sun Jun 20 2021 11:17pm
Download or Print
https://drive.google.com/file/d/18-9XtNlzT...sp=sharing
Post #614969 Mon Jun 21 2021 2:12am
ecs0set
Excellent, thanks. All resolved now as they found the procedure but useful to check the steps!
Post #614971 Mon Jun 21 2021 6:48am
