Home > General (L494) > Knocking noise from rear wheels |
kevin reevse Reeves Member Since: 21 Sep 2020 Location: Windsor Posts: 20 |
When pulling away on gravel or slippery surface there is a loud knocking from rear wheels, more noticeable when pulling out of left or right junctions from standstill. Problem was worse on gravel and uphill, when driving normally no noise. Car is a 2015 autobiography dynamic on 22" rims, as its not all the time it's not bushes, arms or CV joints I don't think. Dealers under warranty said it was tank slap🙄 I'm thinking more like dsc or traction control etc
Mon May 24 2021 8:29pm |
mees Member Since: 17 Jul 2009 Location: bru Posts: 45 |
Yes, i had the same. Double flush transferbox and new software and problem solved 😊 |
Tue May 25 2021 9:32pm |
Hi guys, so was your problem intermittent, how would I tell if that is the problem other than paying for it to be done and hope this is the issue? |
Tue May 25 2021 10:49pm |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
Hi Mees Imy car has developed the same judder when turning from stationary. How much did ot cost if you dont mind me asking please. |
Wed May 26 2021 3:24pm |
Around 400 euro to solve this. Wasn’t cheap, but transformed the car |
Wed May 26 2021 9:36pm |
ecs0set Member Since: 29 Apr 2021 Location: Poole Posts: 34 |
Main dealer confirmed, double flush transfer box and software update. They want £400+ for it, checky beggars, but then they also want £300 to replace a cracked rear fog light (they can FRO on that one)! Seems harsh when it's a problem LR made but then it could be a snapped crank so...
Wed Jun 02 2021 8:26am |
I got a quote from Stratsone in Tottenham for £217 for double flush and renew. |
Wed Jun 02 2021 10:55am |
Wed Jun 02 2021 11:56am |
Sounds competitive! Although it's inside the North Circular so by the time I've paid Mr. Khan, it's probably about the same! |
Wed Jun 02 2021 12:29pm |
Hi guys, thanks for your valued comments, so I found the tech bulletin for this problem, does this mean the dealer should cover the work even if out of warranty?
Sat Jun 05 2021 8:08am |
I've had a quote from the local specialist for < £200 +VAT. No mention from the main dealer on LR contributing.
Tue Jun 08 2021 1:13pm |
I can't upload the bulletin but the ref number is LTB00906NAS4, Google it.
Sun Jun 20 2021 11:17pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4878 |
Download or Print
Mon Jun 21 2021 2:12am |
Excellent, thanks. All resolved now as they found the procedure but useful to check the steps! |
Mon Jun 21 2021 6:48am |
