Home > Technical > DSC light comes on when turning right. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4809 |
steering angle needs calibration probably
Mon Dec 14 2020 6:33pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
Could be an ABS sensor has been knocked when the wheels were changed. That would give it the willies in certain situations. 2012 SDV6 - it's missing a couple of cylinders
Tue Dec 15 2020 12:41am |
Jampot1979 Member Since: 23 Jun 2017 Location: Bedfordshire Posts: 145 |
Thanks guys.
Wed Dec 16 2020 8:53am |
if you have an IID you can calibrate yourself |
Wed Dec 16 2020 1:08pm |
I dont have one |
Wed Dec 16 2020 1:09pm |
Think problem solved...
Wed Dec 16 2020 5:22pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
"Didn't think DSC would be so sensitive to tyre pressures"
Thu Dec 17 2020 3:39am |
!... The DSC activated once on the way to work this morning. Its certainly better than it was, but still a niggle.
Thu Dec 17 2020 9:40am |
36psi all round is a bit low at the back (or high at the front if you prefer). I'd put the pressures to standard (on the label on the driver's door) and then work from there. I tend to run my fronts a couple of psi higher than standard because I find the ATs I run are happier that way. With a pure road tyre, the pressures should work better if the relationship between front and rear pressures follows the standard. i.e. if you go up a couple at the front, go up a couple at the rear too. 2012 SDV6 - it's missing a couple of cylinders
Thu Dec 17 2020 10:26am |
I will try 33psi at front and 36psi at rear as per what is says on the door sticker. I have new michilens tyres fitted.
Thu Dec 17 2020 11:35am |
Also check the rear wheels (brakes) aren't hot on one side compared to the other. After a journey
Thu Dec 17 2020 1:00pm |
So adjusted the pressures to 33psi front and 36psi rears. Driven it around lots of twisty roads and roundabouts and it's behaved.
Thu Dec 17 2020 5:50pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1049 |
I had a very similar problem to you though the effect varied sometimes. Had steering sensor done, made it slightly better. Played around with tyre pressures, no discernible difference. It was a real pain with a trailer on the back!
Thu Dec 17 2020 7:08pm |
Hmmm.. that's food for thought. I do have brembos and have had constant sqeauling brakes for ages. What you say does make alot of sense. This is definitely something I will look into if problem persists.
Thu Dec 17 2020 7:23pm |
