Home > Technical > DSC light comes on when turning right. |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
Thu Dec 17 2020 10:30pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4804 |
Could be.
Sat Dec 19 2020 4:11pm |
I think unlucky 2nd issue |
Sat Dec 19 2020 6:34pm |
Jampot1979 Member Since: 23 Jun 2017 Location: Bedfordshire Posts: 145 |
So, garage managed to relatch my park brake and reset/adjusted the brake shoes. Luckily the epb module seems ok.
Wed Dec 23 2020 11:02am |
Tony666 Member Since: 27 Jul 2011 Location: Barry Posts: 170 |
Are your tread depths even? I had a very similar problem after replacing2 tyres on the rear axle ( due to puncture) with new, (12mm) front were on about 4 mm so left them. I had DSC coming on at roundabouts and the car didn’t feel right at all. Replaced the front two tyres then everything was spot on again. Pressures were fine, it was the difference in tread depth that caused it. |
Fri Dec 25 2020 8:48am |
