Home > General > suspension problem
divvy
United Kingdom 2008 Range Rover Sport TDV6 HSE Zermatt Silver
suspension problem
Hi, I have just serviced my hitachi compressor, although there was no faults on it i thought it was time to give it a new lease of life, when running it for a few seconds it faulted out, checked all fuses were okay and the relay, and the compressor will run fine when crossing out the relay, i pulled the codes with sdd and got,
B1B78-84 HVAC SYSTEM PRESSURE.
U0428-86 ARCM INVALID DATA FROM STEERING ANGLE SENSOR MODULE.
O0434-86 RLM J_14229_DTC U0434.
C1A20-64 RLM J_14229_DTC C1A20.
U0421-94 ATCM INVALID DATA FROM RIDE LEVEL CONTROL MODULE.
U0159-87 IPC LOST COMMUNICATION WITH PARKING ASSIST MODULE
hvac i assume is aircon not cold enough so needs a regas
Confused
any Help on where i go from here most appreciated.
Post #607251 Sun Dec 06 2020 4:11pm
You may need a better fault code reader.
Obvious things
Have you put the 2 small pipes back the correct way.
Maybe you damaged the temperate sensor wires
Post #607253 Sun Dec 06 2020 4:23pm
divvy
Hi thanks for the reply,
i used dealer code reader jlr sdd to retrieve codes, pipes at the rear of the pump are different sizes so no way of mixing them up, pump runs fine crossing out the relay, its as if i am not getting the neg to feed the relay from the ecu.
Post #607255 Sun Dec 06 2020 4:44pm
Find out what those O and C codes mean then.
Search on here or
Disco3
Post #607258 Sun Dec 06 2020 6:14pm
Post #607260 Sun Dec 06 2020 8:54pm
Maybe you haven’t rebuilt it very well and made it worse then.
Or a problem with the pressure sensor. Where is it ?
Post #607261 Sun Dec 06 2020 9:15pm
divvy
Hi pump runs perfect when giving it direct power from the relay, looks to me that something is not giving the signal to the ecu to power the relay, where would i find the pressure sensor on the central valve block ? pump has got plenty of pressure when removing the dryer rear pipe, thanks for the reply.
Post #607268 Mon Dec 07 2020 12:22pm
the ecu isn't seeing a pressure increase at the sensor, so cuts the compressor off.
Post #607273 Mon Dec 07 2020 1:22pm
divvy
Hi, thanks again for your help, i removed the compressor again and removed the solenoid and it was cleaned out as the area was covered in dryer dust particles rebuilt the compressor and it seems fine now cleared fault codes but i still get as soon as i start up the message vehicle lean when cornering and amber light lit, car drives fine, pulled codes again and there is only 2 codes
B1B78-84 SYSTEM PRESSURE AS I NEED AIRCON RECHARGED (PERMANENT DTC)
U0159-87 LOST COMMUNICATION WITH PARKING ASSIST CONTROL MODULE (INTERMITTENT FAULT)
None of these codes will clear, i initially thought the lean when cornering was compressor fault or steering angle sensor but i recalibrated it successfully and fault is still there.
Post #607322 Tue Dec 08 2020 3:36pm
Maybe it is the hydraulic anti roll bars (ACE). I can't really help on them
Ensure you are reading the fault codes on all ECU's, so any ACE faults will be seen
Post #607351 Wed Dec 09 2020 1:03pm
