Home > General > suspension problem |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4797 |
You may need a better fault code reader.
Sun Dec 06 2020 4:23pm |
divvy Member Since: 06 Dec 2020 Location: lanarkshire Posts: 4 |
Hi thanks for the reply,
Sun Dec 06 2020 4:44pm |
Find out what those O and C codes mean then.
Sun Dec 06 2020 6:14pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4847 |
Sun Dec 06 2020 8:54pm |
Maybe you haven’t rebuilt it very well and made it worse then.
Sun Dec 06 2020 9:15pm |
Hi pump runs perfect when giving it direct power from the relay, looks to me that something is not giving the signal to the ecu to power the relay, where would i find the pressure sensor on the central valve block ? pump has got plenty of pressure when removing the dryer rear pipe, thanks for the reply. |
Mon Dec 07 2020 12:22pm |
the ecu isn't seeing a pressure increase at the sensor, so cuts the compressor off. |
Mon Dec 07 2020 1:22pm |
Hi, thanks again for your help, i removed the compressor again and removed the solenoid and it was cleaned out as the area was covered in dryer dust particles rebuilt the compressor and it seems fine now cleared fault codes but i still get as soon as i start up the message vehicle lean when cornering and amber light lit, car drives fine, pulled codes again and there is only 2 codes
Tue Dec 08 2020 3:36pm |
Maybe it is the hydraulic anti roll bars (ACE). I can't really help on them
Wed Dec 09 2020 1:03pm |
