Home > General > Fuel leak.. |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 189 |
Fuel filter is on that side by the drivers door, maybe pipes running from there or to there from fuel tank???
Fri May 29 2020 5:25pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Hmm.. don’t know. As far as I can see there are the two metal fuel pipes fixed to the frame the running along them is this rubber pipe. It’s stopped spraying fuel now the pressure has gone. I sent a photo to my mate at the local garage and even he doesn’t recognise it. I find it odd that there is a rubber pipe in such a vulnerable position for an alleged off road vehicle.. |
Fri May 29 2020 6:02pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4867 |
Any chance it's shown here at all?
Sat May 30 2020 5:30am |
The two lines on the left I assume are petrol fuel lines. The rubber hose in question is the next one along that is connected to that round valve thing. It's got pin holes in it and was spraying petrol all over the place.
Sat May 30 2020 5:35am |
I meant the two lines on the right fixed to the frame are fuel lines.. |
Sat May 30 2020 5:36am |
That does look a little aftermarket fitment of some sort, don't suppose somebody has fitted a electric fuel shut of solenoid for some reason or something like that.
Sat May 30 2020 5:45am |
Well it does have a brc Lpg system on it. Maybe it's something to do with that. |
Sat May 30 2020 6:36am |
Yep. It's part of the lpg system. Don't know what it does though. The rubber hose either side of it have pin holes in so it sprays petrol about. |
Sat May 30 2020 10:55am |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
if its LPG it'll be part of a fuel return line system. |
Thu Jun 18 2020 11:37am |
Fixed now anyway. |
Thu Jun 18 2020 4:35pm |
