Home > General > Fuel leak..
Themoog
Fuel leak..
Disaster.. The wife had been out in the RRSS and came home complaining of a smell of petrol.
Sure enough there are some tiny pin hole leaks in a thin rubber hose that is just under the driver side rear door.
What pipe is that? It's connected to a small round valve with electric connectors on it..
Post #599399 Fri May 29 2020 4:56pm
skid1963
Fuel filter is on that side by the drivers door, maybe pipes running from there or to there from fuel tank???
I'm sure someone will be along to confirm
Edit: just noticed you have SC so could be completely wrong about that Shocked 2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #599402 Fri May 29 2020 5:25pm
Themoog
Hmm.. don’t know. As far as I can see there are the two metal fuel pipes fixed to the frame the running along them is this rubber pipe. It’s stopped spraying fuel now the pressure has gone. I sent a photo to my mate at the local garage and even he doesn’t recognise it. I find it odd that there is a rubber pipe in such a vulnerable position for an alleged off road vehicle..
Post #599403 Fri May 29 2020 6:02pm
Any chance it's shown here at all?
Post #599409 Sat May 30 2020 5:30am
Themoog
Looking at the picture the rear n/S wheel is at the lower left.
Post #599410 Sat May 30 2020 5:30am
Themoog
The two lines on the left I assume are petrol fuel lines. The rubber hose in question is the next one along that is connected to that round valve thing. It's got pin holes in it and was spraying petrol all over the place.
Ive got some fuel pipe in the garage so I'll have another look later and I may be able to repair it.
It would be interesting to know what it is though..
Post #599411 Sat May 30 2020 5:35am
Themoog
I meant the two lines on the right fixed to the frame are fuel lines..
Post #599412 Sat May 30 2020 5:36am
That does look a little aftermarket fitment of some sort, don't suppose somebody has fitted a electric fuel shut of solenoid for some reason or something like that.
Post #599413 Sat May 30 2020 5:45am
Themoog
Well it does have a brc Lpg system on it. Maybe it's something to do with that.
Post #599414 Sat May 30 2020 6:36am
Themoog
Yep. It's part of the lpg system. Don't know what it does though. The rubber hose either side of it have pin holes in so it sprays petrol about.
Post #599415 Sat May 30 2020 10:55am
mgrover
if its LPG it'll be part of a fuel return line system.
Post #600433 Thu Jun 18 2020 11:37am
Themoog
Fixed now anyway.
Post #600445 Thu Jun 18 2020 4:35pm
