Home > General > Help - Compressor not working |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4803 |
The compressor motor wires are easy to follow as they are thick and run from front wheel arch liner down the side.
Sat Oct 19 2019 7:01pm |
triplemmm Member Since: 22 Mar 2014 Location: SE Posts: 77 |
Thanks Andy. So remove wheel arch liner?
Sat Oct 19 2019 7:06pm |
Bridge the 2 large terminal holes
Sat Oct 19 2019 7:35pm |
cheers, will try that tomorrow |
Sat Oct 19 2019 7:56pm |
I bridged the relay connections but got nothing.
Sun Oct 20 2019 10:10pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Check continuity between the relay wiring down to the compressor, then you'll know if it is actually getting power.
Mon Oct 21 2019 8:25am |
WIll do next as I just tried my usual mechanic and he has gone on holiday for 2 weeks!
Mon Oct 21 2019 5:58pm |
they run UNDER the car.
Mon Oct 21 2019 6:39pm |
Great, thanks Andy
Mon Oct 21 2019 9:30pm |
It might.
Mon Oct 21 2019 10:10pm |
Have you had this plugged in at all as yet? a tool that can monitor the solenoids and see what the compressor is actually doing will help here..
Tue Oct 22 2019 7:31am |
Can't see a GAP tool helping much, considing what you have found so far |
Tue Oct 22 2019 12:02pm |
Given the original diagnosis..Fit a new compressor.. after:-
Tue Oct 22 2019 1:09pm |
this is what diagnostic machines aren't the only tool required.
Tue Oct 22 2019 6:03pm |
