Home > In Car Electronics > GPS memory fail |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
I think they are talking rubbish, as I don't believe there is any Backup Battery fitted to the GPS.
Wed Jul 24 2019 10:16pm |
Markymark Member Since: 24 Jul 2019 Location: Gloucester Posts: 16 |
Maybe, maybe not. All I know is that if you put in a destination and start your journey, and happen to turn the ignition off at sometime the destination is lost. Home destination,when put in is lost if you turn off the ignition, in fact everything is lost. Turn on the ignition and it's reset back to Belgium,Grote market to be exact. |
Wed Jul 24 2019 11:39pm |
A little more information may help, like has it just delveloped the fault, have you just bought the car and it was already like it, recently updated the map or removed the battery etc.?
Thu Jul 25 2019 12:08am |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
i'd check the cars battery...if ok try a disconnection reset.. |
Thu Jul 25 2019 9:18am |
The fault has only appeared a couple of months ago. One day ok,next day not ok??!?. Myself and my local Land Rover dealer have reset it back to Gloucester England, switch off and next time you switch it on, your back to Belgium,. Battery new last year,never been off since, still running original mapping software.go figure! |
Thu Jul 25 2019 10:28am |
Probably a GPS antennae issue. It not knowing where it is defaults. There is no backup battery in the IAM, only feed from the car battery. Have you had any work done, even if you believe it to be unrelated? Any very heavy rain? 2012 5.0 SC AB
Thu Jul 25 2019 1:43pm |
I don't know about the antenna, because 1 minute after I turn on the ignition, it goes from Belgium to where I am, but if I go to put in a destination, I have to change the country from Belgium to Great Britain,then all is ok till I turn it off again,then bingo it's back to Belgium again!!!When it's switched on it will find me no trouble,when programmed,no trouble,finds where I want to go and gets me there no problem. It just won't let go of Belgium!!! |
Thu Jul 25 2019 4:33pm |
P.S. my antenna is in the side windows I have no external shark fin |
Thu Jul 25 2019 4:37pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1747 |
It is usually the antennae that has failed.
Thu Jul 25 2019 5:01pm |
Ok, have a read of this TSB, I think this will give you the answer.
Thu Jul 25 2019 5:42pm |
That's rather strange as I thought all the sports had the roof antenna for the GPS. when I had a antenna issue the car never defaulted to Belgium it just didn't know where it was at any time. Cheers Col |
Thu Jul 25 2019 9:11pm |
According to the wiring diagrams and workshop manual, both the RRS and LR4 have the GPS in the shark fin. The rear 1/4 windows have 3 antennas per side. 2 for Tv, 2 for DAB and 2 for AM/FM.
Thu Jul 25 2019 9:30pm |
Or are we talking a 2013 reg 2014 MY L494? 2012 5.0 SC AB
Thu Jul 25 2019 9:34pm |
I think even the RRS2 antenna is roof mounted in the UK market, although there is some aerial/antenna fitted in the rear spoiler for something.
Thu Jul 25 2019 9:56pm |
