Home > In Car Electronics > GPS memory fail |
Markymark Member Since: 24 Jul 2019 Location: Gloucester Posts: 16 |
I will look into this with Land Rover. Sounds expensive one way or another |
Fri Jul 26 2019 12:12am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1748 |
Have a look at these posts: https://www.rrsport.co.uk/forum/search.php...rch_time=0 2023 P440e SE Dynamic on order -cancelled
Fri Jul 26 2019 8:12am |
Well done, there is no way a GPS antennae would be vertical on the glass, it is trying to see the satellites and would be on the roof.
Fri Jul 26 2019 5:24pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4852 |
So is the car 2013 late L320 RRS1 or a early 2013 L494 RRS2? because if it's a L320 the power cable and coax lead to the rear spoiler will be the reversing camera.
Fri Jul 26 2019 7:35pm |
col,its a late L320.it looks like someone has played about with it and fitted what my mate calls a 'T' antenna in the spoiler casing ????(i've no idea either )but LR should sort it next week. |
Fri Jul 26 2019 7:54pm |
Is the car a HSE or SE as I don't think all SE's had navigation fitted and perhaps someone has retro fitted it, not sure but could be a possibly, as strange why roof antenna would be missing, unless of course it has previously packed up.
Fri Jul 26 2019 7:58pm |
Col ,it's a hse black edition in Orkney Gray metallic. It's got TV and everything! |
Fri Jul 26 2019 8:59pm |
Really strange, should have dual view if black edition as well, hopefully fit new aerial and will be back in business little fiddly to replace aerial but the headlining does flex enough without dropping it to far, unless you have hands the size of a shovel
Fri Jul 26 2019 11:34pm |
***UPDATE***
Tue Jul 30 2019 7:44pm |
Right then,got car back from or yesterday, still not got a fully working sat nav.
Tue Aug 06 2019 6:04pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
That’s as per TECHNICAL BULLETIN LTB00642v3 mentioned on page 1. Second hand IAMs are £100 to £200 for the 12/13 MY but a MY14 to 16 should work.
Tue Aug 06 2019 6:11pm |
