Home > General > Buying my first RR 2006, help! |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1245 |
Hi there,
Wed Apr 24 2019 7:04am |
Phillw454 Member Since: 24 Apr 2019 Location: BRISTOL Posts: 3 |
Thanks for the reply, sorry thought the hse only had one engine option, see I know nothing! it’s the tdv6 2.7 diesel. |
Wed Apr 24 2019 7:42am |
HSE was also available in the early days (up to 2007) with a 4.4lt V8 Naturally Aspirated Petrol engine, they are quite rare models - the TDv8 HSE came a little later in March 2007. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Apr 24 2019 9:10am |
Tom_w_27 Member Since: 09 Sep 2018 Location: Norfolk Posts: 40 |
I was in the same boat as you 6months ago. I was dead set on owning one but the horror stories put me off.
Wed Apr 24 2019 6:39pm |
Check to see if the oil pump was changed when the belts were done as some cars of around 2007 suffered with weak pumps yours may be early enough to not had the weaker pump but i think i would be happy if i knew the pump had been changed |
Wed Apr 24 2019 8:53pm |
Mgtow127@gmail.com Member Since: 06 Apr 2019 Location: London Posts: 66 |
My advice would be.......
Wed Apr 24 2019 8:57pm |
Never new the sport was crammed together |
Wed Apr 24 2019 8:59pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8861 |
The difference between RRS and Discovery is about 5 inches in the wheelbase. This is basically in the rear prop shaft. Everything else is basically the same in terms of the drive train. The RRS and Discovery engine bays are basically the same. The issue with space applies to the TDV8, not the TDV6.
Wed Apr 24 2019 9:04pm |
And I thought the troll was leaving as he never has anything positive to say just on everyone else’s new toy |
Wed Apr 24 2019 9:10pm |
What's needed is some strong moderation to nip trolling in the bud. 2012 SDV6 - it's missing a couple of cylinders
Wed Apr 24 2019 9:14pm |
The L494 (RRS2) is designed to be what it is from the ground up, the first RRS sport is basically a Discovery but smaller. It was designed around previously existing platform, unlike the newer RRS2. |
Wed Apr 24 2019 9:21pm |
There are various other adjustment, changes throughout the suspension/driveline. |
Wed Apr 24 2019 9:23pm |
Hi, what are you budgeting the £1500 a year on? A service as I understand is around 3-600ish each year. Baring any faults and a clean MOT what else are you spending on? Also what did you replace in the first 6 months? Thanks. |
Wed Apr 24 2019 11:20pm |
The engine is the same. The gearbox is the same. The transfer box is the same. The front and rear diffs are the same. The suspension arms are mostly interchangeable - indeed one mod for Discos is to use the RRS lower arms as the bushing is considered better. The rear prop shaft is different because Disco is longer behind the transfer box. The anti roll bars can be different because Disco never had Dynamic Response. They are basically the same vehicle with diffetent bodies on them. The RRS wasn't somehow hit with a hammer to make stuff fit inside the smaller body. You make it sound like it was. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Apr 24 2019 11:39pm |
