Home > Technical > Coolant level sensor fault |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
The float is within the tank and can’t be replaced.
Sun Mar 24 2019 7:28pm |
M9G UK Member Since: 02 Feb 2019 Location: Somerset Posts: 160 |
Ok thanks andy, thought I would ask as can buy a tank with sensor on fleabay but you can also buy the sensor separately 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Sun Mar 24 2019 8:22pm |
N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32 |
Sensor is "specific gravity" sensitive, so if coolant does not have enough % of antifreeze it will trigger coolant low warning.
Mon Mar 25 2019 10:06am |
OK cool thanks 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Mon Mar 25 2019 10:34am |
took bottle out and the float was fine and moved freely but the sensor looked dodgy, £8 for a new sensor and job done, no more "coolant level low" messages 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Sun Mar 31 2019 12:48pm |
RR 2012 4.4 TDV8 |
Sun Mar 31 2019 7:11pm |
Pinnacle Member Since: 13 Mar 2018 Location: Romford Posts: 72 |
M9G,
Fri Nov 22 2019 2:54pm |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
I've been having the same message pop up randomly for a while now, have ordered the temperature sender as a stand-alone item, hopefully can just replace it rather than having to replace the whole bottle - can't see why they'd sell the sensor separately if you can't! |
Sun Nov 24 2019 9:35pm |
The issue as I understand it is with the float inside the bottle becoming saturated and not floating as it should.
Tue Nov 26 2019 10:23am |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 120 |
Majority of the time, it isn't the sensor itself but the float within the coolant bottle. If you fill the bottle with water and the float doesn't rise, that's your issue. |
Sun Dec 08 2019 10:27pm |
