Home > Technical > Coolant level sensor fault
M9G UK
So I have had a message flashing up on my screen saying coolant level low but it isn't, I have read this was a common fault and the float fills with coolant.
Question, can the sensor just be replaced or is it sealed within the expansion tank?
Thanks 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Xtrons Android head unit
Smile
Post #577727 Sun Mar 24 2019 3:00pm
The float is within the tank and can’t be replaced.
About £25 for new tank
Post #577743 Sun Mar 24 2019 7:28pm
M9G UK
Ok thanks andy, thought I would ask as can buy a tank with sensor on fleabay but you can also buy the sensor separately 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #577752 Sun Mar 24 2019 8:22pm
N60613
Bosnia Herzegovina
Sensor is "specific gravity" sensitive, so if coolant does not have enough % of antifreeze it will trigger coolant low warning.
float can get stuck on the bottom of the tank , my did. remedi was to remove it and wash with some gasoline until you here flot ratell. wash with detergent and refill with antifreeze. it did work for me.
Thumbs Up RR 2012 4.4 TDV8
Post #577784 Mon Mar 25 2019 10:06am
M9G UK
OK cool thanks 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #577791 Mon Mar 25 2019 10:34am
M9G UK
took bottle out and the float was fine and moved freely but the sensor looked dodgy, £8 for a new sensor and job done, no more "coolant level low" messages Very Happy Very Happy Very Happy 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #578192 Sun Mar 31 2019 12:48pm
N60613
Bosnia Herzegovina
Post #578199 Sun Mar 31 2019 7:11pm
Pinnacle
M9G,
did you get the message constantly or did it keep coming on for a bit then resetting again?
As this is the issue I have but i already placed the tank so maybe need a new sensor.
Post #590817 Fri Nov 22 2019 2:54pm
derekmines
I've been having the same message pop up randomly for a while now, have ordered the temperature sender as a stand-alone item, hopefully can just replace it rather than having to replace the whole bottle - can't see why they'd sell the sensor separately if you can't!
Post #590943 Sun Nov 24 2019 9:35pm
Pinnacle
The issue as I understand it is with the float inside the bottle becoming saturated and not floating as it should.
The sensor is a separate item. The float is built into the bottle itself.
Post #591030 Tue Nov 26 2019 10:23am
erickwan
Malaysia
Majority of the time, it isn't the sensor itself but the float within the coolant bottle. If you fill the bottle with water and the float doesn't rise, that's your issue.
Post #591634 Sun Dec 08 2019 10:27pm
