Home > In Car Electronics > Rear screens and DVD not working |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
they are lost likely after market screens. (quite common).
Sun Jan 27 2019 2:35pm |
Or another option is the dealer fit Roosen screens which they used to fit at vast expense |
Sun Jan 27 2019 2:38pm |
Owain Member Since: 26 Jan 2019 Location: Kent Posts: 6 |
Thanks For your helps guys. The pics attached show ab6 disc holder in the boot the wires under the drivers seat and the rear headbreat with screw and the controls on the door.
Sun Jan 27 2019 4:56pm |
Can’t see a pic in gallery.
Sun Jan 27 2019 4:59pm |
Apologies new to this!
Sun Jan 27 2019 5:03pm |
Yeah there aftermarket ones have you got a remote/headphones with them looks like a dvd slot at the top |
Sun Jan 27 2019 5:19pm |
Hi no there is no remote and there is no slot at the top it looks more like a infra red line (if that makes sense) |
Sun Jan 27 2019 5:29pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
If you think they use Infrared , get some of these headphones
Sun Jan 27 2019 5:45pm |
Hi
Sun Jan 27 2019 5:49pm |
If the units are not working have a look at the rear lighter to see if that works you need to know where the power has been taken and that’s the nearest point or somewhere in the centre cubby if it’s not working check the fuses in the fuse box T front |
Sun Jan 27 2019 5:57pm |
If there power to disc changer sorry see if that turns on but I think the veba ones need a remote to work them as that’s the only way I could make those screens work in my disco 2 |
Sun Jan 27 2019 6:00pm |
Thanks guys.
Sun Jan 27 2019 7:56pm |
Here's a second hand one if the dvd is the same and cheap or try the veba site
Sun Jan 27 2019 8:07pm |
Feenzz Member Since: 06 Aug 2019 Location: MILTON Keynes Posts: 3 |
Hi! I’m having the same issue after changing my head unit due to damaged touch screen. Had to reload the OS but am missing the “rear entertainment” option.
Tue Aug 06 2019 6:37am |
