Home > Technical > Front and rear polyurethane swaybar bushings
turbostang
2008 Range Rover Sport Supercharged Java Black
Just want to share with you guys on my past weekend project.
Over the weekend i replaced the front and rear sway bar bushing with polyurethane bushing from lucky 8. The factory rubber bushing was creaking and knocking badly. (The vehicle bushings was replaced by the dealer 3 times already)
I removed all the sway bar brackets, drilled and tapped grease fittings onto the brackets.
Then I drill a hole and cut a channel in the bushing for the grease to lubricate the bushing.
So far so good, No noises and the vehicle feel tighter during turn. 2008 Range Rover Sport S/C
Post #572731 Thu Jan 10 2019 12:27am
knwatkins
Any difference in ride quality? MY2010 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #572773 Thu Jan 10 2019 3:48pm
turbostang
The ride quality feel firm. Less body roll. And no more squeak. 2008 Range Rover Sport S/C
Post #572791 Thu Jan 10 2019 8:28pm
Brit Plumber
The only thing that would concern me is the attraction of dirt causing premature ware to the material. 2012MY RRS 5.0 Supercharged Autobiography (Current)
Mods:
2016 Discovery 4 Mirrors AKA RRS2 (Done)
2014 L405 Surround Camera retro fit (WIP)
2013 RES Dual View Screen fit (Complete)
2016 LR4 RSE (WIP)
67 plate Focus ST Line (Current)
09 Mondeo 2.2 Titanium X Sport (Gone)
02 Ford Focus TDCI (Brilliant car sadly scrapped)
99 BMW M3GTII (Amazing car, written off By a Fiat)
Post #572793 Thu Jan 10 2019 8:41pm
turbostang
Polyurethane bushing suppose to last a lot longer than the oem rubber bushing . 2008 Range Rover Sport S/C
Post #572814 Fri Jan 11 2019 12:42am
Bardley
"Polyurethane bushing suppose to last a lot longer than the oem rubber bushing."
That's actually not quite right. many have tried these so called 'uprated' bushes, incl. the branded ones, and found that they do not last longer that LR OE. Those reported have used them on all terrain, and road, and they then went back to the rubber type.
The marketing would have you believe that they are so much better, but ask the question why are they not fitted at build by the manufacturers? (.. and that's others not just LR).
I tried Polybush branded on a 300Tdi on it's dampers, and they went soft and had to be changed out in a very short space of time.
Advice is avoid, and fit branded LR. The OP experiences of issues with the dealer(Or Indy ?) would need explaining, and it could well be that there are underlying problems elsewhere causing premature failure in the bushes, (If they were real LR OE). There are now many companies purporting to be making bushes of quality, but this is simply not the case. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #572820 Fri Jan 11 2019 7:27am
turbostang
All 3 pair of sway bar bushings was replaced with oem lr bushing by the LR dealer. The reason the bushing was replaced, the annoying squeak and knock going over uneven road surfaces. I spray silicone lubricant to quiet it down, but it was only temporary. The bushings seem last about 20 to 30k miles. Currently mileage 100450.
Now only time can tell how long the polyurethane bushing will last. I will report back in couple of months to let you know how the bushings holding up. 2008 Range Rover Sport S/C
Post #572835 Fri Jan 11 2019 2:02pm
mermade
It depends on the quality of the poly bushes... companies like powerflex offer a lifetime guarantee on them.
They're not fitted by the manufacturer due to costs and will last their manufacturers warranty period...
https://powerflexstore.co.uk/land-rover/ra...2005-2013/
Post #574042 Tue Jan 29 2019 10:05am
Bardley
Aftermarket suppliers make many claims and these are not necessarily true. I know if Indys and private owners alike that have had bad experiences of short service life, and stick to branded OE as a result. This includes the high profile ones.
The colours and smart packaging, incl. marketing for those that 'think' they are 'upgrading' is misleading at best.
Like many things, Brakes being one example which owners seems to debate alot, it comes down to personal choice and what you think is best at the time. 2011 MY D4 HSE
Post #574045 Tue Jan 29 2019 10:47am
Pufftmw
Powerflex front ARBs here fitted about 2 years ago and 20,000 miles. Since then no squeaking or knocking from the front at all. Prior to that, I was going through ARBs/the pain every 10-15k miles. Driving is a lot of country road, fields and some off-roading. Is it firmer? Probably but nothing that I think impacts ride quality.
Rear's have started squeaking a bit now though Sad
Post #574050 Tue Jan 29 2019 12:49pm
