Home > Technical > Front and rear polyurethane swaybar bushings |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Any difference in ride quality? Kev
Thu Jan 10 2019 3:48pm |
turbostang Member Since: 21 Dec 2012 Location: New York Posts: 10 |
The ride quality feel firm. Less body roll. And no more squeak. 2008 Range Rover Sport S/C |
Thu Jan 10 2019 8:28pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
The only thing that would concern me is the attraction of dirt causing premature ware to the material. 2012 5.0 SC AB
Thu Jan 10 2019 8:41pm |
Polyurethane bushing suppose to last a lot longer than the oem rubber bushing . 2008 Range Rover Sport S/C |
Fri Jan 11 2019 12:42am |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
"Polyurethane bushing suppose to last a lot longer than the oem rubber bushing."
Fri Jan 11 2019 7:27am |
All 3 pair of sway bar bushings was replaced with oem lr bushing by the LR dealer. The reason the bushing was replaced, the annoying squeak and knock going over uneven road surfaces. I spray silicone lubricant to quiet it down, but it was only temporary. The bushings seem last about 20 to 30k miles. Currently mileage 100450.
Fri Jan 11 2019 2:02pm |
mermade Member Since: 09 Jan 2019 Location: manchester Posts: 2 |
It depends on the quality of the poly bushes... companies like powerflex offer a lifetime guarantee on them.
Tue Jan 29 2019 10:05am |
Aftermarket suppliers make many claims and these are not necessarily true. I know if Indys and private owners alike that have had bad experiences of short service life, and stick to branded OE as a result. This includes the high profile ones.
Tue Jan 29 2019 10:47am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1047 |
Powerflex front ARBs here fitted about 2 years ago and 20,000 miles. Since then no squeaking or knocking from the front at all. Prior to that, I was going through ARBs/the pain every 10-15k miles. Driving is a lot of country road, fields and some off-roading. Is it firmer? Probably but nothing that I think impacts ride quality.
Tue Jan 29 2019 12:49pm |
A follow up for the poly bushings for the front and rear sway bars
Tue Apr 07 2020 1:27pm |
Great news. Thanks for reporting back Kev
Tue Apr 07 2020 2:51pm |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 212 |
Mine had polyurethane when I purchased it , they were all removed by my indie when it went in for repairs & a service he doesn't recommend them at all, OE ones now on vehicle. |
Tue Apr 07 2020 3:14pm |
Hey Boxer, why were your bushing replaced? Squeaking?
Tue Apr 07 2020 3:44pm |
Hi Turbostang, I simply bought the RR & searched for an indie by recommendation found a really good one and told him to put right everything he thought needed doing so went with his knowledge & experience, the vehicle did have some rattling from the front when going over speed humps this has all been eliminated now. Goes back in August for its MOT test when the front discs & pads will be replaced. |
Tue Apr 07 2020 4:00pm |
