Home > General > Suspension Fault / Suspension Refresh... (suspension idiot) |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Get the code reader on it first. Then go from there. |
Tue Dec 18 2018 5:27pm |
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 |
Rusk - get your battery checked as well. Mine was dying slowly and started to switch of special programmes including adjusting heights. Previously owned 1999 Disco 2 TD5
Thu Dec 20 2018 11:32am |
Also check that all your tail light lamps are working - a blown lamp at the back can throw up all sorts of warnings on the dash 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Dec 20 2018 12:53pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8851 |
Assuming fuses checked, the compressor and height sensors are the most likely cause. The sensors being the most likely of those two.
Thu Dec 20 2018 4:09pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 387 |
A tip is to check the 4*4 screen, it will show a small flashing red box if there is an issue with a particular corner. helps with fault finding if you don't have a code reader.. |
Fri Dec 21 2018 1:33pm |
RUSK Member Since: 27 Nov 2018 Location: South West Posts: 63 |
Thank you for the help so far...
Sat Dec 22 2018 9:43am |
Check the tyre make and size against the others.
Sat Dec 22 2018 10:36am |
Identical Pirelli Scorpians on all wheels... previously identical Nexxens on all wheels BUT the offending wheel was the one that had a slow puncture. |
Sat Dec 22 2018 11:16am |
Ok I would check tyre pressures, then measure the height of the suspension using a tape measure from the underside of the wheel arch to the top of the center hub cap. (For calibration purposes it’s measured to the center of the cap)
Sat Dec 22 2018 3:13pm |
Happy to do a hard reset... but I don’t seem to have a radio code...
Sat Dec 22 2018 3:19pm |
There is no radio code, just need to reset date, time, and radio stations memory.
Sat Dec 22 2018 3:31pm |
And touching the battery cables together won’t up the electrics!? |
Sat Dec 22 2018 11:27pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
No it won't 2016 Black SDV8 Autobiography
Sat Dec 22 2018 11:34pm |
Did this today - exactly as above, but it doesn’t shift the fault - so looks like a new compressor... BUT, can anyone give me an idea of the labour time on replacing the ride height sensors?
Thu Dec 27 2018 4:20pm |
