Home > Faults & Fixes > Range Rover Sport 2.7 tdv6 white smoke on start |
roksegs Member Since: 12 Nov 2018 Location: Litija Posts: 5 |
Helo all,
Tue Nov 13 2018 7:36am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
I am glad you took my advice and came across to this forum with your issue.
Tue Nov 13 2018 10:17am |
i hope so and thanks u very much for advice me to write my post here. |
Tue Nov 13 2018 10:22am |
maybe somebody else may give some opinion |
Thu Nov 15 2018 2:41pm |
I’d be more concerned with the issue of no compression on no.1 cylinder, that’s youre issue. 2012 5.0 SC AB
Thu Nov 15 2018 3:37pm |
what about this chuckling in engine wich can u hear in video.
Fri Nov 16 2018 9:33am |
The sound and the lack of engine compression is clearly related. What was going on when the noise started? How do you know you have low compression.
Fri Nov 16 2018 10:27am |
If you think of what cylinder 1 is doing, the piston is trying to compress about 450cc of air into a small gap. If you don’t have compression it’s because there is a gap that air is escaping through. The exhaust valve will open and let out the uncompressed air and fuel mixture on the exhaust stroke. Depending on where the air goes on the compression cycle will have an effect on noise and damage to the engine. You could end up with fuel in the oil, over pressure of the cooling system, water in the oil etc. Etc. Hopefully it’s a cylinder head gasket and not a warped/cracked head. I’m convinced if you fix the misfire, the noise and white smoke will be gone. 2012 5.0 SC AB
Fri Nov 16 2018 10:33am |
Its start like that to car make white smoke just on start at evening, after 10-15 sec he run normal without any smoke or any clunking sound in motor. After 5 days i just going home and i start hearing this clunking sound in the motor,...
Fri Nov 16 2018 11:02am |
Anyone know if the 2.7 has variable cams? I wonder if the mechanic suspects the variable cams seized. 2012 5.0 SC AB
Fri Nov 16 2018 6:37pm |
