Home > Maintenance & Modifications > Aaagh... It's the EAS again.... Help!! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
The pipes are continuous between valve block and each air bag so far as I am aware. Likewise, between the corner valves and the reservoir valve block. The only joints are where the pipes attach to a fitting (reservoir, compressor, valve blocks, air bag). 2012 SDV6 - it's missing a couple of cylinders
Mon Nov 05 2018 12:43pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Thanks RRSTDV8
Mon Nov 05 2018 12:53pm |
The joints use Voss connectors which can be changed. 2012 SDV6 - it's missing a couple of cylinders
Mon Nov 05 2018 5:20pm |
Thanks RRSTDV8,
Tue Nov 06 2018 10:50am |
