Home > General > Help please - work done, now something doesn't look right!
Richythepom
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi all,
I've just had some work complete don my '08 RRS - the fuel breather pipe was identified as leaking at my recent service, so I agreed to have them replace it. The thing is - I never paid much attention to the fuel cap area before I had the work done, but when I came to re-fuel yesterday (first time since having the work done) - somethng just looks wrong, or missing....
Could I ask a huge favour of any early RRS owners, please? Could someone have a look behind their fuel flap and take a pic to compare to the pics I've attached?
Am I imagining it or is something amiss?!
Many thanks!
 2008 RRS HSE Stornoway Grey
Post #564049 Tue Aug 28 2018 8:20am
It looks like they have put on the later filler neck. The earlier version - as on your 08 - was metal and didn't have the misfuel device in it. Would be worth picking up the reset device just in case you activate the misfuel device at some point. 2012 SDV6 - it's missing a couple of cylinders
Post #564052 Tue Aug 28 2018 8:39am
Richythepom
Thanks for the quick reply. It's tricky to see from my pic, but in the photo with the cap off, you can just about see a thin bit of black plastic runs around the edge of the whitish/grey circular piece with the hole in the middle. This piece of black plastic looks as though it's broken around the edges to me. Any thoughts? 2008 RRS HSE Stornoway Grey
Post #564055 Tue Aug 28 2018 8:54am
Looks to me like they have ripped off part of the rubber seal that locates in a groove in the top metal part of the filler neck.
Post #564056 Tue Aug 28 2018 9:23am
Richythepom
Thanks Col - worth complaining about and getting the garage to sort? I sit something I can sort myself with a nice new stanley knife blade?! 2008 RRS HSE Stornoway Grey
Post #564057 Tue Aug 28 2018 9:27am
This is what it should look like, I think they have actualy torn the rubber seal when they pulled the filler neck out, so would need replacing.
Post #564059 Tue Aug 28 2018 10:05am
Richythepom
Thanks again Col - I'm going to contact the garage and ask them to sort... heaven knows they've had enough of my hard-earned! 2008 RRS HSE Stornoway Grey
Post #564060 Tue Aug 28 2018 10:10am
This is what you or should I say they will need around £45.00 LR014044
Post #564061 Tue Aug 28 2018 10:35am
Richythepom
That's great - many thanks again for your help. 2008 RRS HSE Stornoway Grey
Post #564063 Tue Aug 28 2018 10:56am
Richythepom
I emailed the garage and got the following reply -
"I’ve just checked with the technician and it’s only a rubber filler nothing to worry about "
The thing is - to me, it is something to worry about as it's not 'perfick' and I've paid hundreds of pounds for a fuel breather pipe to be replaced! Am I being petit? 2008 RRS HSE Stornoway Grey
Post #564067 Tue Aug 28 2018 12:27pm
No, it's not petty to expect them to do the job correctly.
Was this at a LR dealer garage? 2012 SDV6 - it's missing a couple of cylinders
Post #564069 Tue Aug 28 2018 12:37pm
Richythepom
No, it's a LR-specialist Indy in Essex. 2008 RRS HSE Stornoway Grey
Post #564070 Tue Aug 28 2018 12:41pm
PEACHY
Their answer - reply is simply not good enough !! could it be classed as dangerous ?
Good luck 16MY Estoril Blue SVR.............
Post #564077 Tue Aug 28 2018 6:33pm
Brit Plumber
It was put there for a reason.
Turn it back on them...if it is “only a seal”, they won’t mind replacing it!! 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #564099 Wed Aug 29 2018 7:54am
Richythepom
Thanks all.
The seal is there, it just doesn't sit flush around the edge of the metal neck filler and looks like it's been cut with a blunt blade or something - leaving a jagged edge.
So I don't think it's a safety issue, it just looks a bit crap... 2008 RRS HSE Stornoway Grey
Post #564103 Wed Aug 29 2018 9:45am
