Home > General > Help please - work done, now something doesn't look right! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
As I said they have ripped part of the seal away, it should locate in a groove in filler neck and form a nice tight seal, it is not possible to buy the seal seperate you or they will need to replace the complete part LR014044 which I posted a picture of. If they had done the job correctly they would not have torn it in the first place.
Wed Aug 29 2018 10:36am |
Richythepom Member Since: 01 Aug 2015 Location: Essex Posts: 68 |
Thanks again, Col. I've emailed them the LR part number. Let's hope they don't try and bill me for it and/or the work! 2008 RRS HSE Stornoway Grey |
Wed Aug 29 2018 10:45am |
Here is a better picture of the seal which is damaged.
Wed Aug 29 2018 11:03am |
Dropped my RRS in to the garage today to get the work done/looked at. Was immediately greeted with being told the rubber was old and that these rubber bits perish as they get old and get regularly covered in diesel, so it just split as they were putting it back over the metal filler neck etc. etc.
Wed Sep 12 2018 1:46pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1239 |
i'd like to think that any decent garage would let you know of anything found along the way 2006 2.7 TDV6 HSE in Cairns Blue. |
Wed Sep 12 2018 3:22pm |
Well, £170-odd later, I've just picked her up with the seal fixed.
Wed Sep 12 2018 5:19pm |
If it was as they say then they should have informed you before handing the car back or asked you if you wanted it replaced as it was not in good condition it sound's like someone there is a bit of a cowboy or the apprentice did it and said nothing if i were you i would not use them again |
Wed Sep 12 2018 6:13pm |
Was it a LR indie? 2006 2.7 TDV6 HSE in Cairns Blue. |
Thu Sep 13 2018 6:38am |
Yeah - a LR specialist in Essex... 2008 RRS HSE Stornoway Grey |
Thu Sep 13 2018 7:05am |
