Home > General (L494) > Deployable side step settings. |
All accessory installation and operating instructions can be downloaded from the JLRTopix website in pdf format 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Aug 27 2018 6:09pm |
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 |
Hi Tim.
Mon Aug 27 2018 6:45pm |
Cornishman Member Since: 12 Jul 2018 Location: Cornwall Posts: 27 |
You are correct, booklet part number VPLWPO182, “ To switch DSS on.. Press and hold switch, Press and hold Stop/ Start button, the button will flash 3 times . To turn off repeat the same , and button will flash 2 times “ The steps will not deploy if speed is above 5 kph or train response is set to ...mud/ sand or rock crawl. Hope it works for you.. |
Mon Aug 27 2018 7:09pm |
Hi Cornishman.
Mon Aug 27 2018 7:19pm |
Eventually I have found this on YouTube
Mon Aug 27 2018 8:19pm |
HXM Member Since: 24 Jun 2018 Location: Up North Posts: 81 |
I’ve got the dss booklet in the car I’ll take photos tomorrow MY15.5 HSE - SDV6 - Santorini Black |
Mon Aug 27 2018 10:26pm |
Hi HXM.
Mon Aug 27 2018 10:39pm |
Odd video, my My16 works as I described, press function switch then ignition on and yellow light on function switch will flash. Then turn ignition off , door open or closed. |
Tue Aug 28 2018 10:03am |
Thanks again for all your help
Tue Aug 28 2018 4:13pm |
Terras14 Member Since: 04 Mar 2018 Location: Singapore Posts: 38 |
I have a most strange encounter with my DSS recently.
Wed Sep 05 2018 6:01pm |
