Home > Maintenance & Modifications > Bluetooth Factory Kit Install ( HHHEEELLPP ) |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
Which number are you having a problem with?
Tue Jul 24 2018 6:36pm |
Kirbs Member Since: 21 Jul 2018 Location: Suffolk Posts: 13 |
Hi image 157 plug B cheers |
Tue Jul 24 2018 6:59pm |
Hi Andy all the plugs are in and bluetooth not seen when searching.Its the cam lock plug that does not seem to be included in the comic strip instructions that i am having problems with locating its other half. its not plug b as i stated earlier but its the one above it in the picture 157. this is the end of the harness supplied.
Sun Jul 29 2018 12:00pm |
removed. |
Sun Jul 29 2018 12:12pm |
Look at page 16 of the insptructions. The wiring diagram.
Sun Jul 29 2018 12:26pm |
right so you think it is for a phone cradle is that what you mean? it would be long enough to reach
Sun Jul 29 2018 1:04pm |
also the car has voice command fitted and a mic in the centre light so is there a module is should be looking for or do i install the second mic with the kit? |
Sun Jul 29 2018 1:15pm |
It wouldn't surprise me if you still get the "phoned not fitted message" even when working, as its a ford bolt on kit.
Sun Jul 29 2018 2:06pm |
hi, just checked the colour codes on the harness and they match those on the wiring diagram in the fitting instructions as you mentioned for plugging into the base plate connector.
Sun Jul 29 2018 4:44pm |
