Home > Technical > Cant seem to calibrate my suspension?
lamb190
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Rimini Red
I have the IID blue tooth tool. With the latest software. Cant get the air suspension to the set height of 461/465 i set it to this but it doesnt correct it. My rear seems to keep going to 475/480 and front 450mm.
This is doing my head in.
In the height adjust settings i cant seem to lower the rear - only raise?
What am i doing wrong?
Spencer
Post #561458 Mon Jul 16 2018 4:18pm
PC76
Good morning Spencer,
are you setting the suspension to tight tolerance, and then driving it for a 50m or so to let it settle? i usually just reverse mine off the drive and back on once in tight and then set the suspension.
also having read another post where Disco_Mickey suggested that the height sensors which reports a totally different voltage will probably be faulty.
Post #561482 Tue Jul 17 2018 8:11am
lamb190
To be honest i dont "set it to tight tolerance" i just adjust each corner as instructed in suspension calibration.
How do i set it to tight tolerance?
If my rear height sensors were faulty would this show up as errors or do they just go "out of range"?
(I dont have any suslension faults)
GAP Diagnostics said that my heights might just be down to a +/- 10mm tolerance.
But this still doesnt let me lower the rear hight in height setting via IID (its at max adjust)
Spencer
Post #561486 Tue Jul 17 2018 9:11am
PC76
Re-tight mode i have just read the guide and it is not required for the calibration so don't worry about that.
See page 97 of the user guide, it states to use the live values to confirm the current height calibration, you can also select to view the voltages for each height sensor. if the voltages are very different on the same axel then i believe this might indicate a potential issue. Perhaps Disco_Mikey will advise better..
Post #561488 Tue Jul 17 2018 10:40am
lamb190
Ok will check this.
Thanks
Post #561489 Tue Jul 17 2018 11:50am
PC76
Hi Spencer, how have you got on with this?
Post #561550 Wed Jul 18 2018 4:43pm
lamb190
Ive been too busy to check again. But will check corner voltages asap. The car is sitting ok at a glance. But will check as i think i set the rear to -7
Spence.
Post #561571 Wed Jul 18 2018 9:24pm
PC76
Ok, I would set the height adjust to normal and then calibrate the suspension. Once you have calibrated then use the height adjust function to lower to your preferred height.
Post #561596 Thu Jul 19 2018 9:33am
lamb190
This is what i did before (setting height to normal) i will try and have a play tomorrow. Thumbs Up
Post #561633 Thu Jul 19 2018 6:53pm
