Home > Technical > Cant seem to calibrate my suspension? |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 386 |
Good morning Spencer,
Tue Jul 17 2018 8:11am |
lamb190 Member Since: 12 Jun 2015 Location: bristol Posts: 80 |
To be honest i dont "set it to tight tolerance" i just adjust each corner as instructed in suspension calibration.
Tue Jul 17 2018 9:11am |
Re-tight mode i have just read the guide and it is not required for the calibration so don't worry about that.
Tue Jul 17 2018 10:40am |
Ok will check this.
Tue Jul 17 2018 11:50am |
Hi Spencer, how have you got on with this? |
Wed Jul 18 2018 4:43pm |
Ive been too busy to check again. But will check corner voltages asap. The car is sitting ok at a glance. But will check as i think i set the rear to -7
Wed Jul 18 2018 9:24pm |
Ok, I would set the height adjust to normal and then calibrate the suspension. Once you have calibrated then use the height adjust function to lower to your preferred height. |
Thu Jul 19 2018 9:33am |
This is what i did before (setting height to normal) i will try and have a play tomorrow. |
Thu Jul 19 2018 6:53pm |
