Home > General > amber light surspension fault
rizlajon
United Kingdom 2006 Range Rover Sport TDV6 HSE Santorini Black
hi all. hope someone can help its driving me mad.. soon as I put key in to start range the amber light comes on that's even before I start engine and the front of car is dropped. only way I can get the car to normal height is to put key in don't turn on and press button to lower turn key start engine amber light comes on but if u press raise the car will go to normal then stop at standard height u can drive car but got to do this each time and amber light stays on all the time.. no fault codes comes up
Post #561396 Sun Jul 15 2018 9:29am
Disco_Mikey
If the Amber light has come on, there will be a code stored.
Sounds like you need a better code reader
Post #561397 Sun Jul 15 2018 9:43am
Leave the car in access mode fur now?
Post #561398 Sun Jul 15 2018 10:15am
rizlajon
this is why its doing my head in ranger rover said there are no codes coming up so could be a number of things wrong. I was not going to pay there prices to put stuff on I didn't need just so they could tick it of the problem box. was hoping someone had this problem before and knew the problem
Post #561401 Sun Jul 15 2018 11:16am
Brit Plumber
So are you saying the car drops the front end when you leave it? Like Air is leaking over time? If that’s the case it seems like the car knows it should be at one level (normal) but it detects the front is at access.
How quick does this reoccur after you’ve turned the car off? I know you say every time but that would mean the front is lowering the moment you turn the car off. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #561406 Sun Jul 15 2018 5:26pm
rizlajon
the front drops slowly if u lave it for an hour or so the 4x4 screen shows the front as dropped a little the green bar comes back up to normal when u reset the surpension to normal. it drops right down over night. ill see if I can take pics when I go to car later
Post #561407 Sun Jul 15 2018 6:04pm
Brit Plumber
I think the first thing you need to do then is identify the leek. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #561408 Sun Jul 15 2018 6:27pm
Brit Plumber
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #561409 Sun Jul 15 2018 6:30pm
Brit Plumber
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #561410 Sun Jul 15 2018 6:31pm
Brit Plumber
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #561411 Sun Jul 15 2018 6:32pm
Brit Plumber
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #561412 Sun Jul 15 2018 6:33pm
geoffsnook
There'e a valve block at the front behind the bumper on drivers side i think they have been known to leak Thumbs Up
Post #561415 Sun Jul 15 2018 7:07pm
geoffsnook
Duplicate appears to be a slight issue here with post's Thumbs Up
Post #561418 Sun Jul 15 2018 7:10pm
Cymruambyth
Wales
I think we got it Laughing Steve.
Post #561422 Sun Jul 15 2018 8:40pm
Brit Plumber
Sorry about that, the page kept freezing and I hadn’t realised it had posted each time. Good job I gave up after 3 attempts!! 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #561425 Sun Jul 15 2018 9:03pm
