Home > General > amber light surspension fault |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
If the Amber light has come on, there will be a code stored.
Sun Jul 15 2018 9:43am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
Leave the car in access mode fur now? |
Sun Jul 15 2018 10:15am |
rizlajon Member Since: 22 Jan 2015 Location: london Posts: 8 |
this is why its doing my head in ranger rover said there are no codes coming up so could be a number of things wrong. I was not going to pay there prices to put stuff on I didn't need just so they could tick it of the problem box. was hoping someone had this problem before and knew the problem |
Sun Jul 15 2018 11:16am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
So are you saying the car drops the front end when you leave it? Like Air is leaking over time? If that’s the case it seems like the car knows it should be at one level (normal) but it detects the front is at access.
Sun Jul 15 2018 5:26pm |
the front drops slowly if u lave it for an hour or so the 4x4 screen shows the front as dropped a little the green bar comes back up to normal when u reset the surpension to normal. it drops right down over night. ill see if I can take pics when I go to car later |
Sun Jul 15 2018 6:04pm |
I think the first thing you need to do then is identify the leek. 2012 5.0 SC AB
Sun Jul 15 2018 6:27pm |
Sun Jul 15 2018 6:30pm |
Sun Jul 15 2018 6:31pm |
Sun Jul 15 2018 6:32pm |
Sun Jul 15 2018 6:33pm |
There'e a valve block at the front behind the bumper on drivers side i think they have been known to leak |
Sun Jul 15 2018 7:07pm |
Duplicate appears to be a slight issue here with post's |
Sun Jul 15 2018 7:10pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
I think we got it Steve. |
Sun Jul 15 2018 8:40pm |
Sorry about that, the page kept freezing and I hadn’t realised it had posted each time. Good job I gave up after 3 attempts!! 2012 5.0 SC AB
Sun Jul 15 2018 9:03pm |
