Home > Maintenance & Modifications > Coolant leak RRSS 4.2 |
Take your time i just did mine and it took a bit of time to bleed it use the bleed valve on the header bottle and the other small one that is on the pipe coming up from the aux pump it took me a while to get heat into the heaters |
Sat Jun 30 2018 6:38pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
It isn't the pipe connection.. the metal pipe that is attached to the bottom of the rad and curves around and towards the back has a pin hole in it. I had to remove most of the front of the car just to see it.
Sun Jul 01 2018 8:33pm |
Nor was mine it was the pipe that feeds the supercharger which the pully had managed to damage but still a to bleed |
Sun Jul 01 2018 8:38pm |
I've just been searching for the rad on the web and it seems to be the intercooler rad. I thought intercooler rads had air in them not water.. is the supercharger water cooled then? |
Sun Jul 01 2018 9:00pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4794 |
yeah supercharged ones are "chargecooled"
Sun Jul 01 2018 9:53pm |
yes it is needed to help with the cooling as the supercharger is at the top of it's operating temp |
Mon Jul 02 2018 8:46am |
Well. The car is in pieces all over the drive... I've got the rad drained and disconnected but due to the stupid pipes it won't come out of the space..
Mon Jul 02 2018 11:18am |
Undo the slam panel at the top there are 4 star drives I think then pull it up out of the way |
Mon Jul 02 2018 11:31am |
rads are generally mounted together these days.
Mon Jul 02 2018 12:07pm |
Got it out...
Mon Jul 02 2018 12:10pm |
I removed- bumper, headlights, cross beam, plastic front rad cowling, plastic intake, top rad shroud and various other brackets etc.
Mon Jul 02 2018 12:17pm |
It's not going to plan.. I ordered a new rad from Rimmer bros via UPS next day delivery. After waiting all day I got a call from someone several miles away saying they had a box delivered addressed to me.
Tue Jul 03 2018 8:53pm |
Update if anyone is interested..
Thu Jul 05 2018 5:38am |
Well I think it's fixed.. just checked the coolant level this morning and it's the same as yesterday- for several days every morning I would have to put in .5 litre of coolant and I was thinking there was still a leak. I even put a sheet of cardboard under it overnight to check.
Mon Jul 09 2018 8:12am |
