Home > Technical > camshaft sproget |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
Has a key way. Only fits one way... |
Sat Jun 16 2018 8:11pm |
blueiceplus Member Since: 21 Feb 2014 Location: wigan Posts: 66 |
thanks but I've took the 3 bolts out, and the pulley back part is still bolted to the camshaft by the centre bolt and the pulley will fit in 3 different position and the manual doesn't say. |
Sat Jun 16 2018 8:50pm |
Why was the pulley removed?
Sun Jun 17 2018 7:18am |
Thanks for your help, I'm still a bit confused about how to lock the camshaft in position, I will look at the manual, I have noted today that the part on the camshaft as an arrow on it, and I know that the sprocket as a marker line on it, should they line up To cars had a small battery fire, and the belt cover is one of the parts that I've changed.
Sun Jun 17 2018 3:28pm |
If you didn’t lock the cam shaft, I’d be a little worried that your timing will be out. Have you disassembled the belt, pulley and tensioner? 2012 5.0 SC AB
Sun Jun 17 2018 4:01pm |
https://www.instagram.com/p/BiWWpH9g2Sp/?u...8g8slxqzlt
Sun Jun 17 2018 4:52pm |
