Home > Technical > Do you use the EPB at the traffic lights? |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1127 |
Curious as to whether anyone does this?
Tue Jun 12 2018 9:32am |
Mine doesn't have auto start/stop, so I just leave it in D --
Tue Jun 12 2018 10:10am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
I tend to use it if the brakes are hot
Tue Jun 12 2018 12:03pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
I use it if stopped for a while, ie. temporary road works traffic lights, you know the ones that take forever! 2016 RRS SVR Estoril Blue
Tue Jun 12 2018 2:12pm |
Thanks for the answers.
Tue Jun 12 2018 2:17pm |
My feeling is that it's better than putting strain on the gearbox leaving it in Drive and also (but probably totally rubbish) that if it's used, there's less chance of it seizing up! 2016 RRS SVR Estoril Blue
Tue Jun 12 2018 2:19pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
There is no "strain" on the gearbox at tickover with the EPB applied. The only connection between engine and gearbox under those circumstances is via the fluid in the torque convertor. So no wear can take place.
Tue Jun 12 2018 2:52pm |
Thanks Wilf, I wasn’t aware of the fact it can cause more wear moving back and forth through N and D.
Tue Jun 12 2018 6:44pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
Never ever used it, although when I was on a Range Rover experience day on the main road the instructor said to use it in an emergency (assuming you think about it) He told me to drive at a steady 50mph (no following traffic) then flick it on without taking my foot of the accelerator. I nearly went through the windscreen, it was that powerful |
Tue Jun 12 2018 7:16pm |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 |
I use the EPB if there is a long wait or if it’s dark and I want to avoid dazzling the driver behind with my brake lights. I try to release the brake manually because I’ve been told that the auto release wears the rear brake pads prematurely - don’t know how true this is . . . .
Tue Jun 12 2018 7:51pm |
