Home > Technical > Fusible link blown.
Howler
England 2005 Range Rover Sport Supercharged Buckingham Blue
Fusible link blown.
Hi all, I have put a question about my suspension in another thread, but I think I have found the fault in the engine compartment fuse box and it is the fusible link 60amp that has blown.
My question is; should I take into a garage to get sorted or can I find somewhere that sells fusible links and replace it myself?
Many thanks.
Post #558294 Wed Jun 06 2018 1:45pm
you can get them off ebay for example.
The coloured ones? or a metal bar ?
Post #558327 Wed Jun 06 2018 7:04pm
Howler
Hi Andy, yes the small square yellow 60amp one, the one that does the compressor circuit. I assume you just pull the old one out like you do a fuse?
Post #558331 Wed Jun 06 2018 7:43pm
Yes. Called j fuses on eBay
Post #558338 Wed Jun 06 2018 9:15pm
Brit Plumber
Its probably blown for a reason. Is the compressor tired and drawing to much current? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #558345 Wed Jun 06 2018 9:41pm
Howler
Thank's Andy.
Brit Plumber, not sure about that? Tired maybe I wouldn't have a clue about the voltage? I've just dug through some old info I had a fault code of C1A20-64, pressure increases too slow when filling reservoir - Algorithm based failure - signal plausibility failure., but that was in April 17. Since then an occasional yellow light but it always cleared, this time it just went yellow warning light and wouldn't go off, and just found the j-fuse popped!
Post #558348 Wed Jun 06 2018 10:20pm
Better get a couple of fuses.
As the new one could blow straight away.
If it does. Disconnect large compressor wires.
If it blows then it's the cars wiring.
You can swap the fuse for a 55w headlight bulb to help trace wiring shorts.
When the bulbs on bright the short exists
Could use a 100 or 130 w on this circuit
Best to bridge relay out if doing this
Post #558350 Wed Jun 06 2018 11:09pm
Howler
Ok thanks Andy, I was going to order a few just in case, actually knowing my luck the first one would have popped just to wind me up Laughing
If it gets to using light bulbs or bridging the relay then that is beyond my knowledge i'm afraid, but thanks for the suggestions.
Post #558368 Thu Jun 07 2018 9:10am
let me know how you get on
Post #558380 Thu Jun 07 2018 12:03pm
Howler
Will do, just ordered x2 of the blighters. Thumbs Up
Post #558382 Thu Jun 07 2018 12:12pm
Howler
Hi all, an update to this thread.
Bought two j fuses blown them Rolling Eyes So have had to book in to a garage for a diagnostic. Had a conversation with the guy who told me that if it is the compressor then all in it will be £1100 Big Cry to do as the compressors have been up graded to an AMK speck? and have to get direct from landrover and it will then need to be coded to my car ?
Any thoughts?
Post #559818 Mon Jun 25 2018 4:05pm
PC76
Hi Howler, try Advance factors for the parts they are a forum sponsor and offer a good service.
Also Bodsy posted a step by step guide to replacing the compressor try looking at the below link..
http://www.rrsport.co.uk/forum/topic28424.html
Post #559824 Mon Jun 25 2018 4:51pm
I don't think hitachi compressors are available anymore? (or costly) so AMK fitted and it required a software update.
cover doesn't fit too well afterwards either
Post #559829 Mon Jun 25 2018 6:21pm
Howler
Hi PC76 and Andy K, the garage will do the diagnostics on Thursday so I will be in a better position then to know what is needed to be done.
Thanks for the info, I have seen the topic that you have linked to PC6I7, I will see what is quoted by the garage and then contact Advance Factors and see what they can do if it is the compressor that is needed.
Will update when I know more.
Many thanks,
Post #559871 Mon Jun 25 2018 10:13pm
Howler
Hi all, further update.
The diagnostic was carried out today and the compressor was verified as the fault, ( not holding pressure) the local 4x4 garage i am intending to use say they will only use genuine LR parts and have in their quote listed the following
part number: (LR072537LR) .
I shall of course take my time in perusing the tinternet for a more moderate price for the part in question and I will of course contact Advanced Factors to see if there compressor is the same as needed and a better price than I was quoted.
Will further update when I know more.
Many thanks....
Post #560166 Thu Jun 28 2018 5:26pm
