Home > Technical > AC condenser replacement |
Half way there |
Sun May 13 2018 11:55am |
Yep the other one is the gearbox cooler |
Sun May 13 2018 1:02pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
I got so far in but gave up. A bit disappointed but i dont have time now.
Sun May 13 2018 9:01pm |
My lpg lube is where the spare battery would go but i know what you mean it is really tight i did mine at a friends garage so had access to what ever i needed but it was a pig and i did have to split the rad pack and drain off some of the coolant |
Sun May 13 2018 9:05pm |
Update.
Mon May 14 2018 1:02pm |
Mon May 14 2018 1:36pm |
Just out of interest, what spare battery? |
Mon May 14 2018 2:08pm |
Back left as you look from the front under the plastic cover thats where you could but a second battery |
Mon May 14 2018 2:12pm |
Ah.. Mine has the lpg things under there and the flashlube is behind the coolant bottle front right. |
Mon May 14 2018 2:17pm |
Got the car back today after having the condenser replaced. Total was £420.
Wed May 23 2018 3:38pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4797 |
They don't have electric fans as these cars are designed to be used as slow speed in muddy fields.
Wed May 23 2018 6:55pm |
Good grief. Can anyone do anything correctly.. Now ill have to take it back to get them to put it right. And im gonna wait while they do it. |
Wed May 23 2018 8:40pm |
The plot thickens.. I took it back and he said it should have 900g in. So I called a Land Rover dealer and they said 900g too. I still think it should be 600g.
Thu May 24 2018 1:16pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Just knoticed this thread.
Thu May 24 2018 5:55pm |
