Home > Technical > AC condenser replacement |
Don’t quote me but aren’t you supposed to be licensed to work on AC because of the environmental risks? Or is it just the filling/vacuuming side of it? 2012 5.0 SC AB
Fri May 11 2018 12:36pm |
You can work on them but you are supposed to get the gas recovered by a specialist but as its already escaped you can do it and it involves a bit of dismantling of the front end ie bumper headlights crash bar and top part of slam panel book sys 4-6 hours but if the bumper bolts are taking them out is a pita |
Fri May 11 2018 3:45pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Do all the rads have to come out or can the condenser be taken out on its own.? |
Fri May 11 2018 4:14pm |
If you can separate them then all the better im sure it says you can but i found it easier to take the 3 out as it was tight |
Fri May 11 2018 4:18pm |
I should have 2 quotes from land rover specialists near me in the next day or so. The car wont be needed all next week so i could fanny around with it myself.
Fri May 11 2018 4:36pm |
Will not be cheap |
Fri May 11 2018 5:05pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
I would like to think the front chargecooler rad is seperate.
Fri May 11 2018 6:46pm |
They are all separate and you can undo them it’s quite tight in there with the 3 of them I also used an aftermarket one which was just over £140 inclusive of vat |
Fri May 11 2018 7:23pm |
Chuff me.. The first quote is £770. I think thats a bit rich.. Lets se what the second is. |
Fri May 11 2018 7:43pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
700 stings |
Sun May 13 2018 8:17am |
I would have thought £300-400 would be about right.
Sun May 13 2018 8:57am |
its really a case of how seized the slam panel bolts are around the headlights
Sun May 13 2018 10:23am |
Apart from the fact there are 3 rads on the supercharged which does make it harder than the disco 3 as i can testify as i have done both of them now |
Sun May 13 2018 10:32am |
Ive started...
Sun May 13 2018 11:46am |
