Home > Technical > AC condenser replacement
Page 1 of 3 123>
Themoog
Got a leak at the bottom of the ac rad where a stone has hit it due to the tow eye cover missing..
Anyway, Ive had a quick look and its possible I can swap one myself. Has anyone done this job or has any tips? It looks sandwiched between other rads..
Post #556193 Fri May 11 2018 9:56am
Brit Plumber
Don’t quote me but aren’t you supposed to be licensed to work on AC because of the environmental risks? Or is it just the filling/vacuuming side of it? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #556198 Fri May 11 2018 12:36pm
geoffsnook
You can work on them but you are supposed to get the gas recovered by a specialist but as its already escaped you can do it and it involves a bit of dismantling of the front end ie bumper headlights crash bar and top part of slam panel book sys 4-6 hours but if the bumper bolts are Censored taking them out is a pita Thumbs Up
Post #556204 Fri May 11 2018 3:45pm
Themoog
Do all the rads have to come out or can the condenser be taken out on its own.?
Post #556205 Fri May 11 2018 4:14pm
geoffsnook
If you can separate them then all the better im sure it says you can but i found it easier to take the 3 out as it was tight Thumbs Up
Post #556206 Fri May 11 2018 4:18pm
Themoog
I should have 2 quotes from land rover specialists near me in the next day or so. The car wont be needed all next week so i could fanny around with it myself.
Wait and see what the quotes are..
Post #556207 Fri May 11 2018 4:36pm
geoffsnook
Will not be cheap Rolling with laughter Thumbs Up
Post #556210 Fri May 11 2018 5:05pm
I would like to think the front chargecooler rad is seperate.
Personally I would go for an aftermarket condenser.
These things corrode whether geuione or not.
Post #556217 Fri May 11 2018 6:46pm
geoffsnook
They are all separate and you can undo them it’s quite tight in there with the 3 of them I also used an aftermarket one which was just over £140 inclusive of vat Thumbs Up
Post #556219 Fri May 11 2018 7:23pm
Themoog
Chuff me.. The first quote is £770. I think thats a bit rich.. Lets se what the second is.
Post #556220 Fri May 11 2018 7:43pm
d-9
700 stings
Post #556310 Sun May 13 2018 8:17am
Themoog
I would have thought £300-400 would be about right.
If anyone can confirm that it is possible to get the condenser out without removing the other rads then im gonna do it later today. If all the others need to come out too then im not sure if i can be bothered with all the hassle.
Post #556319 Sun May 13 2018 8:57am
its really a case of how seized the slam panel bolts are around the headlights
guide on a diesel to give you an idea
https://www.disco3.co.uk/forum/air-con-con...=condenser
Post #556323 Sun May 13 2018 10:23am
geoffsnook
Apart from the fact there are 3 rads on the supercharged which does make it harder than the disco 3 as i can testify as i have done both of them now Rolling with laughter
Post #556324 Sun May 13 2018 10:32am
Themoog
Ive started...
Post #556329 Sun May 13 2018 11:46am
Page 1 of 3 123>
