Home > In Car Electronics > 2005 cd error. |
Welcome you need to read the book there is a menu you need to enter and tell it you want to insert the discs i think its the menu button on the left |
Sun Apr 29 2018 2:27pm |
Sun Apr 29 2018 2:31pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
Thanks. Im sitting in it now. I pressed cd, menu, load all. The screen just says 'cd2' top left and 'cd error' in the middle. If i press eject it just hums. |
Sun Apr 29 2018 2:48pm |
Ive been trying to get the rear tvs on too. They work but the main dash screen searches but just says 'no disc' even though ive put some in the carrier in the boot. Im hoping the lens is dirty and just needs a clean.. |
Sun Apr 29 2018 3:49pm |
Take it back to the garage where you bought it and tell them to fix/have a look for you if you bought it from a garage that is |
Sun Apr 29 2018 4:17pm |
This is bizarre.. The rear dvd screens play normal cds, a lens cleaner that i have (it shows a picture and plays music when cleaning) and a copy dvd of I am Legend. It wont play kosha dvds like Toy Story etc.. Just says 'no disc'.
Mon Apr 30 2018 7:04pm |
I wonder if it’s for a different region? I wouldn’t know if the region can be changed or not. 2012 5.0 SC AB
Mon Apr 30 2018 8:58pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
I think you can change the region using a Gap IID Tool (maybe others too but I can't comment on them).
Tue May 01 2018 10:31am |
Right.. Its a region code that needs changing somehow. I went through all the kids dvds and picked out only those that were universal region or region 2 + others and they play ok.
Tue May 08 2018 12:26pm |
Anyhow, I did the first run with the DVD playing in the back... Low and behold my daughter said she felt car sick after 10 min.
Sun May 20 2018 5:00pm |
If it's a factory fitted rear DVD system you can put the DVD's in the carrier in the boot and then control from the front Nav screen if DVD is on or off in the back and still listen to the radio in the front. (The rear passengers will need to plug headphones into the door controls if it's anything like mine.)
Sun May 20 2018 5:14pm |
It is factory.
Sun May 20 2018 5:20pm |
From memory (It's too late to go and look tonight) you have an option on the Nav screen when you select DVD? to then choose "rear entertainment".
Sun May 20 2018 11:27pm |
