Home > General > Can I fit LEDs to side indicators?
Stevepd
I'm thinking of going back to orange side repeaters, but can I fit LEDs instead of halogen jobbies purely for longevity and light output.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #553954 Thu Apr 12 2018 10:11pm
Yes I believe so. They are on the same circuit as the rear indicators
Personally I wouldn't bother. Can sometimes be a hassle getting one of small enough size to fit the indicator unit.
Post #553991 Fri Apr 13 2018 11:20am
Cymruambyth
Wales
Yes Thumbs Up Steve.
Post #554003 Fri Apr 13 2018 12:11pm
Stevepd
Thanks everybody. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #554010 Fri Apr 13 2018 12:44pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I fitted LED bulbs to the side indicators. They work with no problems and I had no problems fitting them.
Post #554030 Fri Apr 13 2018 4:18pm
Cymruambyth
Wales
Do you mean you`re putting orange lenses on and you want normal clear, orange flashing bulbs? Steve.
Post #554038 Fri Apr 13 2018 5:22pm
Stevepd
I currently have clears with orange bulbs, but thinking of going to orange lenses with non coloured bulbs. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #554117 Sat Apr 14 2018 7:31am
Meiang
The general rule of fitting LED bulbs is use red LED bulbs for red lensed lamps, orange LED bulbs for orange lensed lamps and white LED bulbs for clear leansed lamps (reverse). If you use white LED bulbs in either red lensed lamps or orange lensed lamps the emitted light has a very washed out look.
Post #554140 Sat Apr 14 2018 11:47am
Cymruambyth
Wales
Right, with you now Very Happy Yes you could do that but as said above.....may look washed out. I got my orange flashing clear ones off ebay Thumbs Up Steve.
Post #554142 Sat Apr 14 2018 11:50am
Meiang
These are the LED bulbs I use in my door mounted indicator repeaters.
https://www.ebay.com/itm/PIAA-H-522-TERA-E...mp;vxp=mtr
Post #554144 Sat Apr 14 2018 12:00pm
Stevepd
Again thanks everybody Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #554156 Sat Apr 14 2018 3:07pm
