Home > General > Can I fit LEDs to side indicators? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
Yes I believe so. They are on the same circuit as the rear indicators
Fri Apr 13 2018 10:20am |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Yes Steve. |
Fri Apr 13 2018 11:11am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1232 |
Thanks everybody. 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri Apr 13 2018 11:44am |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
I fitted LED bulbs to the side indicators. They work with no problems and I had no problems fitting them. |
Fri Apr 13 2018 3:18pm |
Do you mean you`re putting orange lenses on and you want normal clear, orange flashing bulbs? Steve. |
Fri Apr 13 2018 4:22pm |
I currently have clears with orange bulbs, but thinking of going to orange lenses with non coloured bulbs. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sat Apr 14 2018 6:31am |
The general rule of fitting LED bulbs is use red LED bulbs for red lensed lamps, orange LED bulbs for orange lensed lamps and white LED bulbs for clear leansed lamps (reverse). If you use white LED bulbs in either red lensed lamps or orange lensed lamps the emitted light has a very washed out look. |
Sat Apr 14 2018 10:47am |
Right, with you now Yes you could do that but as said above.....may look washed out. I got my orange flashing clear ones off ebay Steve. |
Sat Apr 14 2018 10:50am |
These are the LED bulbs I use in my door mounted indicator repeaters.
Sat Apr 14 2018 11:00am |
Again thanks everybody 2006 2.7 TDV6 HSE in Cairns Blue. |
Sat Apr 14 2018 2:07pm |
