Home > In Car Electronics > Broken Dab arial
doyleywood
Broken Dab arial
Just managed to damage the dab arial plug that plugs in to the radio/head unit, it’s a real tight squeeze and I bent the little metal tangs, anyway can the plug be replaced? Anyone know where the dab arial wire gos from the back of the head unit, is there a connection anywhere under the dash, thanks in advance
06 sport SC
Post #553821 Wed Apr 11 2018 8:28pm
I didn't even realise a 06 plate car even have dab radio, thought it came in with the facelift.
Post #553827 Wed Apr 11 2018 9:11pm
doyleywood
Same here, but the arial defo dab connection.
Post #553828 Wed Apr 11 2018 9:20pm
Might be worth posting a photo of the damaged plug, could help identify it to see if it can be replaced.
Post #553832 Wed Apr 11 2018 9:57pm
doyleywood
Factory wiring really tight, hard to get the plug to line up square while holding the head unit up close.
Post #553851 Thu Apr 12 2018 8:47am
doyleywood
See photos in gallery
Post #553857 Thu Apr 12 2018 9:17am
doyleywood
Post #553859 Thu Apr 12 2018 9:44am
Socast
It's not DAB, but it is very similar to a fakra connector, that plug looks well and truly goosed though.
You could cut the damaged plug off and replace it with a new one, its a standard co-ax type wire though so may be a bit of a pig to do neatly and also shield from interference.
Post #553884 Thu Apr 12 2018 12:03pm
That is a Fakra plug the colour of it will tell you which one you need, unless you use a sort of Aqua coloured one which is universal fit. As said that will be a real pain to solder and crimp in do in situ. due to limited room I would think.
Post #553886 Thu Apr 12 2018 12:40pm
doyleywood
Oh right, that explains why the plug would not fit the dab unit i was trying to fit, hence the damage! Where could i buy this fitting?
Post #553887 Thu Apr 12 2018 12:42pm
Could Google Fakra Connector and see what comes up, sure I got some off Amazon in days gone bye or possibly ebay.
Post #553889 Thu Apr 12 2018 12:48pm
scarey
i think martin might sell these in the forum 'shop'....
Post #553901 Thu Apr 12 2018 3:38pm
PC76
look for a right angled connector though as a straight may foul something to the rear..
Post #553921 Thu Apr 12 2018 5:40pm
Brit Plumber
May be a pain but if your fitting a DAB head unit, why don’t you fit a dab aerial and save fixing that one? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #553936 Thu Apr 12 2018 6:58pm
RobP
Agree fit a proper DAB antenna
This one gives fantastic reception http://www.dabonwheels.co.uk/Kinetic_DRA-6...erial.html TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #554116 Sat Apr 14 2018 12:44am
