Home > Wheels & Tyres > Tyre-pressures |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
I didn`t check mine until I noticed one tyre was obviously low....pressure was 15 I`d had it almost 5 months. I now have 38 in the fronts and 40 in the rears. Check every couple of weeks now. Or fill with nitrogen and check every 6 months. Steve. |
Mon Mar 12 2018 7:02pm |
533clive Member Since: 15 Nov 2017 Location: Andover Posts: 9 |
Noticed my nearside front looked low, it was, down at 15. Thought I’d better get it checked out in case it was a slow puncture.................OH NOOOOOO, that would be the cheap option.....................only cracked an alloy!!! |
Mon Mar 12 2018 9:10pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 747 |
Evey time I walk to the car on the driveway, I give it a quick visual check. The last thing you want to do is to drive half a mile down the road to find out that you've knackered a perfectly good tyre that was flat when you set off. Plus if you see it's flat on your drive, you can change it there and then with access to your tools/jack/scruffy clothes.
Tue Mar 13 2018 12:04am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Couple of times a month, usually just after a wash together with checking fluid levels.
Tue Mar 13 2018 6:50am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Every couple of weeks, reducing the consumption of tyres and fuel running up and down the A303 everyday. I use a pencil gauge and did have one of those Ring compressors but it seemed very fragile so just use the local Morrisons then adjust; although the Garage pump is not far off what the pencil gauge says.....
Tue Mar 13 2018 8:51am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Not often enough apparently. Checked them the other day to find OSR was low. Pumped it up but it went down over 4-5 days. So slow puncture! Took it to be fixed yesterday - "Sir, we've not repaired your tyre as its getting near the mark and you're going to need a new one soon".
Tue Mar 13 2018 9:18am |
