Home > Maintenance & Modifications > Climate Control Rubber/Plastic switches
Zilch
Location: Currently Hong Kong, sometimes Sydney, Whitsundays or occasionally sunny Buckinghamshire
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
A quick question, is it possible to source just he 3 rubber/plastic controls for the Aircon unit.
Local Land rover dealerships and independents say its a whole new unit at $1500 Australian.
All i need is the outer rubber/plastic parts that you use to control the air flow/air con speed
and the individual temperature controls.. all three seem to be melting/softening, solvent
contamination maybe
Thanks Another Pommie Bar Steward down under
3.0 TDv6 Fuji/Ebony/Anigre, locking Diff thingy, Towpack, sunroof, rear camera, high beam annoyance and a very brand new $25 Supercheap Auto cargo net... plus.. wait for it.. OL bull bar, winch, lightforce driving lights, LR raised intake/snorkel, bash plates, rock sliders and step out protection bars.. ATR tyres.. Hibernating.....
2.7 RRS TDv6, Zermatt/Ebony GONE.AGES AGO.....
Post #550174 Fri Mar 02 2018 6:29am
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
In my 2010 TDV8 the temperature display started to deteriorate. The whole unit - read everything had to be replaced.
Post #550206 Fri Mar 02 2018 11:13am
order a 2nd hand unit from the UK.
and take the bits out.
Post #550209 Fri Mar 02 2018 11:44am
Brit Plumber
I’ve seen pressed stainless knobs that are shaped the same as the knob, they slide over the top of the rubber. They look good but I did see they obscure the marking around the outside i.e. the red and blue on the temp one. 2012MY RRS 5.0 Supercharged Autobiography (Current)
Mods:
2016 Discovery 4 Mirrors AKA RRS2 (Done)
2014 L405 Surround Camera retro fit (WIP)
2013 RES Dual View Screen fit (Complete)
2016 LR4 RSE (WIP)
67 plate Focus ST Line (Current)
09 Mondeo 2.2 Titanium X Sport (Gone)
02 Ford Focus TDCI (Brilliant car sadly scrapped)
99 BMW M3GTII (Amazing car, written off By a Fiat)
Post #550286 Fri Mar 02 2018 6:53pm
Fitted some of those to mine, they are actually plastic, thought they blended in well with rest of silver parts to give it a bit of contrast, didn't bother about red and blue scale being covered as has led read out anyway. Fitted them on rear vents as well for a bit of contrast.
Post #550289 Fri Mar 02 2018 7:43pm
Zilch
Thanks all, col where did you order the stainless caps from, might be worth a try
Jim Another Pommie Bar Steward down under
Post #550294 Fri Mar 02 2018 10:20pm
China Jim where else, Rolling with laughter
They are actually plastic but the quality is pretty good and fit well enough. Say's Disco 4 but fit Sport as well, delivered to NZ o.k.
https://www.ebay.co.uk/itm/5pcs-Dashboard-...2843b06461
Post #550298 Fri Mar 02 2018 10:55pm
Zilch
Thanks col I will get some ordered up Thumbs Up Another Pommie Bar Steward down under
Post #550311 Sat Mar 03 2018 8:33am
Brit Plumber
That’s them, they look better than I thought. I didn’t realise they were plastic but if the quality is there then that’s fine. 2012MY RRS 5.0 Supercharged Autobiography (Current)
Mods:
2016 LR4 RSE (WIP)
Post #550372 Sat Mar 03 2018 8:20pm
Zilch
deed has been done, delivery in about 6 to 8 weeks Shocked Col assume they just press
over the top of existing switches?
Cheers Another Pommie Bar Steward down under
Post #550378 Sat Mar 03 2018 11:02pm
Mine quoted several weeks but only took a week or so, inside the cover is a ring of 3M VHB tape just peel of backing tape, they virtually locate themselves on existing knob and press down lightly to stick in place, I actually took the knob off and stuck the cover on first then pushed knobs back onto panel as didn't want to apply to much pressure to the switch panel. On the larger temp control one's I actually fitted a extra ring of tape first to raise height a small amount, as I found one of them rubbed very slightly on the panel in one position which having slight OCD annoyed me Laughing probably pot-luck really as only one did it.
Post #550382 Sun Mar 04 2018 12:09am
Zilch
Post #550383 Sun Mar 04 2018 1:33am
Zilch
Fixed
Post #560923 Sat Jul 07 2018 10:56am
