Home > Maintenance & Modifications > Climate Control Rubber/Plastic switches |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2833 |
A quick question, is it possible to source just he 3 rubber/plastic controls for the Aircon unit.
Fri Mar 02 2018 6:29am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
order a 2nd hand unit from the UK.
Fri Mar 02 2018 11:44am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
I’ve seen pressed stainless knobs that are shaped the same as the knob, they slide over the top of the rubber. They look good but I did see they obscure the marking around the outside i.e. the red and blue on the temp one. 2012 5.0 SC AB
Fri Mar 02 2018 6:53pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4817 |
Fitted some of those to mine, they are actually plastic, thought they blended in well with rest of silver parts to give it a bit of contrast, didn't bother about red and blue scale being covered as has led read out anyway. Fitted them on rear vents as well for a bit of contrast.
Fri Mar 02 2018 7:43pm |
Thanks all, col where did you order the stainless caps from, might be worth a try
Fri Mar 02 2018 10:20pm |
China Jim where else,
Fri Mar 02 2018 10:55pm |
Thanks col I will get some ordered up Another Pommie Bar Steward down under
Sat Mar 03 2018 8:33am |
That’s them, they look better than I thought. I didn’t realise they were plastic but if the quality is there then that’s fine. 2012 5.0 SC AB
Sat Mar 03 2018 8:20pm |
deed has been done, delivery in about 6 to 8 weeks Col assume they just press
Sat Mar 03 2018 11:02pm |
Mine quoted several weeks but only took a week or so, inside the cover is a ring of 3M VHB tape just peel of backing tape, they virtually locate themselves on existing knob and press down lightly to stick in place, I actually took the knob off and stuck the cover on first then pushed knobs back onto panel as didn't want to apply to much pressure to the switch panel. On the larger temp control one's I actually fitted a extra ring of tape first to raise height a small amount, as I found one of them rubbed very slightly on the panel in one position which having slight OCD annoyed me probably pot-luck really as only one did it.
Sun Mar 04 2018 12:09am |
Sun Mar 04 2018 1:33am |
Fixed
Sat Jul 07 2018 10:56am |
