Home > Technical > Ctek extention cable
Wayneclarke
Is it ok to put two extension cables together so I can make 5 metres in length as I can only find 2.5 m cables
Post #549907 Tue Feb 27 2018 4:11pm
Cymruambyth
Wales 2006 Range Rover Sport Supercharged HST Zermatt Silver
I never thought of that Laughing I wanted a longer one! Steve.
2006 Zermatt Silver, Range Rover Sport HST 4.2 Supercharged on 22" Stormer Alloys.
Post #549910 Tue Feb 27 2018 5:05pm
Mr Stuart of D3 fame posted about this on D3 forums. He asked CTEK, who said No.
Given the price of them, I'm sure there must be a better solution (like having a connection at the rear of the car) or maybe the front ?
Post #549921 Tue Feb 27 2018 6:47pm
Lindab
I have two 2.5m cables joined together on mine, no problem. Never even gave it a thought when I did it
Post #549938 Tue Feb 27 2018 8:03pm
Wayneclarke
i wonder why cute would say no, and if thats the case then why not provide longer cables
Post #549946 Tue Feb 27 2018 8:51pm
there will be a voltage drop along their thin cables.
which may cause intermittent problems.
I like to put a charging socket in the boot.
Didn't stop you though Whistle
Cymruambyth wrote:
Well.....strangely...after buying a 12v plug in adapter for my CTEK...my rear socket which seemed to be permanent live the other week, apparently isn`t Rolling Eyes
Not to be beaten....I "made" a route from the battery to the boot Laughing
Comfort connector from battery to door and inside the Sport
Then the extension fitted and run through the inside to boot
Then charger plugged into 240v extension and into the garage.....where there`s a will there`s a way Laughing Bit of a palava but it`ll only be done once in a while Thumbs Up
NOTE TO SELF.....UNPLUG BEFORE DRIVING OFF Mr. Green
Post #549950 Tue Feb 27 2018 9:06pm
wilf
I too have two 2.5M cables joined together, never had a problem. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #549969 Tue Feb 27 2018 10:15pm
Lindab
I have had 2 cables feeding my F type Jag since November with no problems & also my Range Rover which is used once every week or so. No problems. The ctek lights are all as they should be
Post #549977 Tue Feb 27 2018 11:16pm
Good to hear. I didn't think there would be a problem in practice but ctek say no.
Post #549980 Tue Feb 27 2018 11:20pm
PC76
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Adriatic Blue
Problem would happen mainly when charging a dead battery or running as a supply as the voltage drop is directly related to the amount of current being drawn.
for those that are interested it's calculated as mv*a*m diveded by 1000 (milivolts * amps * meters)/1000
Post #549986 Wed Feb 28 2018 12:35am
wilf
All that would happen is the charging would take a little longer, since the volt drop would fall as the charging current drops off, and the charger would automatically compensate for it. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #549995 Wed Feb 28 2018 9:00am
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
