Home > Technical > Ctek extention cable |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
I never thought of that I wanted a longer one! Steve. |
Tue Feb 27 2018 5:05pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4780 |
Mr Stuart of D3 fame posted about this on D3 forums. He asked CTEK, who said No.
Tue Feb 27 2018 6:47pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 867 |
I have two 2.5m cables joined together on mine, no problem. Never even gave it a thought when I did it |
Tue Feb 27 2018 8:03pm |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
i wonder why cute would say no, and if thats the case then why not provide longer cables |
Tue Feb 27 2018 8:51pm |
there will be a voltage drop along their thin cables.
Tue Feb 27 2018 9:06pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
I too have two 2.5M cables joined together, never had a problem. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Tue Feb 27 2018 10:15pm |
I have had 2 cables feeding my F type Jag since November with no problems & also my Range Rover which is used once every week or so. No problems. The ctek lights are all as they should be |
Tue Feb 27 2018 11:16pm |
Good to hear. I didn't think there would be a problem in practice but ctek say no. |
Tue Feb 27 2018 11:20pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
Problem would happen mainly when charging a dead battery or running as a supply as the voltage drop is directly related to the amount of current being drawn.
Wed Feb 28 2018 12:35am |
All that would happen is the charging would take a little longer, since the volt drop would fall as the charging current drops off, and the charger would automatically compensate for it. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Wed Feb 28 2018 9:00am |
